Looking to insulate unfinished garage ceiling which is 24" center 2x4 truss. 27 x 24 two car garage
Looking between all three big box (what is in stock at each) stores I have a few options
1) Buy R13 Faced Roll fiberglass (23" x 32')
---This would provide no seems although not quiet sure stapling this would be the easiest approach , maybe i can screw some braces to help hold the roll up..like midway and at each end then staple as i go
2) Buy R13 Faced Batt Fiberglass (23" x 93")
---This would be easier to install as it is shorter section, but each cavity would have approx 4 seems
After this is complete
3) Buy R30 UNFACED Roll Insulation and run perpendicular over top the R13
---This is cheaper than running R30 UNFACED Batts, but would / may require some more cutting to get the fit right
4) Buy R30 UNFACED Batts and run perpendicular over top the R13
---Most costly option of the R30 on top, also would introduce more seems
Thanks for the help! Looking to stay warm this winter!!
