CAMMShaft
About 7 years ago while our home was being built I plumbed my attached shop with PEX for air. There are 9 drops in the walls/ceiling connected to my 80 gallon compressor. Unfortunately, I have a leak somewhere that I cannot locate. I am losing about 30-40 PSI in a day. I turn the compressor off at the breaker when I am done using it each day and up until now have had little pressure loss from one day to the next. I have done the soapy water test on all drops/joints that I can access, including crawling in the attic, so the leak must be behind the drywall somewhere. Any suggestions of how to find the leak?
I am in the process of building another shop which is detached. I was planning to run PEX again for air, but now I am having 2nd thoughts.
CAMM
CAMM
