mannydantyla
Hi guys, I'm getting ready to renovate my 20x12 garage and I'm starting by repairing the foundation. I'm doing this DIY because I cannot find a contractor who isn't too busy right now. But I feel like this is pretty doable for a guy like myself who has a little construction experience. I have done lots of reading and youtube watching but it always helps to get direct advice!
The problem is pretty obvious: the structure was built onto hollow blocks (clay bricks I think) that were not filled with rebar and cement, were not tied to each other in any way except mortar, and were not tied to the concrete footing either.
But the good news is that there IS a solid concrete footing. Except in one small spot, in one corner, where it is crumbling and will need repaired. I don't know how big the footing is, it seems to be at least 18" deep and I have no idea how wide. If it's wider than 8" then the blocks were not placed in the center. I'm in Kansas and our code for a small garage like this is 12" deep footings that are 12" wide.
Here's the other corner where the footer is crumbling:
You can see there isn't as much below the blocks on that side, that's because it's crumbled away. You can also see that a previous home owner tried to hold the blocks together with two 2x4s and large screws. That did not work! The blocks are totally lose and I can wiggle them by hand.
The blocks are 4x8x12 and there is two courses of them as well as two layers of them. I want to replace them with new 8x8x12 or 8x8x16 blocks. And I will fill them with rebar and concrete.
Here are my questions:
Any* help is greatly appreciated! Thank you!
* please don't say I need to tear down the whole thing and replace because that's not happening
- Should I lift the wall off of the blocks and replace them all at once? Or could I do it one at a time? The sill plate is actually in good condition
- If the wall needs to be lifted, what is the best way to do that? The wall is only 12' long and is the gable end so most of the roof weight is going to the other walls.
- How can I fasten the new blocks to the old footer? Will I need to drill hole for rebar and use epoxy or something?
- What should I do about the crumbling footer in one corner only?
- Anything else I should be aware of?
