Spark Plug Boot Pliers??
jeepnut24
Morrison CO
A bit of a noob question, but I have always pulled them by hand.... What is the benefit of the pliers, and how do you use them properly? I think Im going to have to pick some up for my current project. The wires just don't want to pop off of the plugs...:headscrat
Fedwrench
Valley of the sun
Spark plug boot plier depending on the type, can reach where your fingers can't, won't get burned as easily as your fingers, and can give you more leverage than your fingers. Just remember to twist the boot from side to side to loosen it first, and then pull. It also helps to grasp the boot as close to the bottom edge as possible to keep from pulling the boot off in half.:beer:
mrshaun
Killeen - Fort Hood
2004 suburban with a 5.3 worst thing I have ever done in my life ( working on cars that is ) after an hour of chewing away at the plug wire boot I gave up. I tried every damn thing off the truck. nada. the guys at the dealership laughed and told me to let them have it. they hate them as well though. the boot was "glued" to the plug. I had to break the tip of the plug off to get the plug out. the boot was definitely not going to fall off going down the road.
J
jeepnut24
Morrison CO
HEY thats the motor!!! Its going in my Jeep....:bounce::(
toolmutt
Texas
I'm about to change the plugs in my wife's 2006 Tahoe. I already now that the boots don't want to let go and that the back one on the passenger side is pretty well barricaded in. Any suggestions on pliers or other tips?
(Sorry if I hijacked the thread.)
Fedwrench
Valley of the sun
If you have compressed air available. A flattened piece of tubing bent like a J, attached to an air gun works great for cooked on boots. Hook the curve of the J under the bottom edge of the boot, blow some air, and the boot is usually free. :beer:
mrshaun
Killeen - Fort Hood
these boots on the 5.3 seem to be "welded" to the plug. I twisted the boot around about 20 times and it was still stuck. I tried everything I could.
J
jeepnut24
Morrison CO
Again the same motor so no problems....:bounce:
mooman
CHICAGO, IL
I'd have a extra set of plug wires ready.
I'm glad I did when I tried to change them on my 5.3L
dede2897234
Northern, Ohio
Toolmutt,
I have used this Lisle adjustable spark plug boot puller a few times on my 2003 Subaru Forester with great success:
http://www.lislecorp.com/divisions/products/?product=320. It is a quality tool.
Here is a link to the Lisle tool on Tooltopia:
http://www.tooltopia.com/lisle-51750.aspx.
Dave
Misfit
I hear a lot of people have problems with the 5.3's. I don't know if its because I have small hands or what but I haven't had too many problems with pulling the wires off? I did break a few wires on one but they were getting changed anyway so it was no biggie.
Now the mitsubishi's did it the smart way by putting the intake OVER some of the plugs and wires :thumbup:
toolmutt
Texas
pay someone to do it for you.
This is an option that I've considered but I was afraid I would have to turn in my man-card and sell all my tool if I paid to have spark plugs done.
I've heard many people recommend this. I'm just going to plan on replacing them all.
Perfect! I need to get a few SK wrenches but they didn't quite add up to the fifty dollar minimum for the free shipping special. I'll try these pliers.
This also sounds like great tip. Thanks for all the help, guys.:beer:
Jeeper
Round Rock, TX
I had a similar problem on a GM3.8 engine. I used a hook from my craftsman pro hook and pick set. I didn't have much luck with the lisle boot pliers. The boots were too stuck.
00947077000
Brandon_Lutz
Forest Hill, Louisiana
Last time I changed plugs on my truck, I couldn't get the plug boot off due to the angle of the steering shaft and I couldn't bend my arm to get a good hold with my fingers.
I took a flat piece of thin iron strap we had laying around and bent about an inch and half of the bottom into a 90 degree angle. Then I traced the boot of one the new plug wires I was going to use onto the bent piece and then cut a half circle notch out of the metal.
Worked like a charm. I threw the "new tool" into the toolbox for future use.
J
jeepnut24
Morrison CO
I am very jealous. Do you have a build thread link you could post?
Not here, and its going slower than I would like... But family is more important, and I pay WAY too much attention to the little details.
I got the boots off. I just kept pulling till they popped off. Thanks for the advice all...:beer:
Moose-LandTran
The Brink of Insanity (England)
I've dealt with similar things. Used something like this:
http://www.tooltopia.com/schley-68450.aspx
Well, i bought some aluminium tube, sharpened the end until it was like a blade, then slipped it down, quick tap down on the end of it to cut the seal, and pulled it straight out.
Dealing with broken-off coil packs isn't fun either. Had a few of those, where the coil pack itself snapped off the top of the boot. Used a flat piece of thin steel, sharped the end and edge like a blade and tapped it down with a hammer to slice through the rubber. Used a screwdriver to break the two parts of the steel casing.
quattrojon
England
A.S.T make a kit for removing VAG ignition coils, which avoids damage to the plastic coil head.
dede2897234
Northern, Ohio
Moose,
Thanks for sharing the link to the Schley tool available through Tooltopia. I did not know such a tool existed! I appreciate all of the lessons you have shared from your automotive repair experiences. I have learned quite a bit from you in the last two years I have been a member.
Thanks,
Dave
quattrojon
England
Moose,
Thanks,
Dave
Moose is a good bloke.... he's helped me out several times by correctly diagnosing mechanical maladies that i've had.
Moose-LandTran
They don't always work, sometimes the coil packs are just brittle and they break apart. I've had some break while using the VAG dealer tool. Like the broken plug i just dealt with, sometimes it don't matter what tools you got, things are going to break. :(
Moose,
Thanks,
Dave
Thank you, Dave. I'm glad you like the little hints and tips. Most have come about for those "Oh ****" moments i often run into. As they say, neccessity is the mother of invention. :)
