Powering a 12v whinch from 120v
Don1357
Palmer, AK
is there a high amperage transformer that would let me run a 12v whinch form regular household electrical power? I have a 4-wheeler which that I would like to fabricate into a ceiling hoist with an I-beam.
BillK
Beautiful Southern Maryland
Keep in mind the winch will not work that great as a hoist because most of them do not have a brake to keep it from running back out when you take the power off. I have been working on a setup in my shop and thought about a winch but it looks like I am going to have to bite the bullet and go with an actual 12v hoist which is a lot more expensive.
D
Don1357
Palmer, AK
I don't know if this would be that huge a deal for me... I have a second floor with a side open bellow and I have been struggling to get heavy stuff up there. As long as I can hoist it up and into the floor I'm happy. Also getting **** off the bed of the truck. I don't see an application where I would need it to be suspended in the air for long.
Sevenhills1952
Virginia
If you try to build a 120vac to 12vdc power supply that supplies 30, maybe 50 amps of current that's going to be more expensive than if you just buy a 120vac harbor freight winch.
If you really want to use that 12vdc one then my suggestion would be use the proper gauge wires (depends on distance of course), but my guess, 4 or 2 gauge. Put battery jumper cables on ends. When you want to use it (like picking stuff out of truck) then connect to truck battery.
You'll have to have truck being charged by running or on a charger.
There are supplies like this that may do it, but over $100.2020_12_12_19.45.22.jpg
Sent from my SM-S205DL using Tapatalk
nadogail
Coronado, CA
Do you have a way to measure the draw of the winch under load? I would use my clamp on meter.
laser3kw
northen IL
I think the first thing you need to do is make sure of the amperage of your winch. I am betting a lot more than 20-30 amps.
a search for a winch brought me to a 2500lb (smallest I could find) and the manual states 132 amp @ 2500lb pull.
so a 120v ac to 12v ac transformer will need to be at least 15 amp on the line side. Then you will need a ac to dc converter (rectifier) that will handle 150 amp. Sure, you may never tax the winch at full capacity, but if for some reason you snag something and stall it, you would smoke a lot of parts.
consider the battery option.
Noltz
Ontario, Canada
best bet: deep cycle battery and battery tender. (disconnect battery tender before use)
Quoted for truth. This is by far the easiest solution. A decent size battery, say for an F150, and a small battery tender will make sure it's always ready.
D
Don1357
Palmer, AK
150 -200A might be a bit closer.
This is a cheap 4-wheeler winch, which runs off the dinky 4-wheeler batteries and dinkier generator.
Heck it is rated for 2,000 pounds and I don't plan on going pass say 400# so I'll be using about a fifth of the rated power.
lonestardiver
This is a 4-wheeler winch, which runs off the dinky 4-wheeler batteries and dinkier generator.
Granted, but those little 7AH and 12AH batteries can put out enough amps to start a V8...but a SLA or starting battery (like what you have in your car/truck would be sufficient. When not being used keeping it on a battery tender should work well.
dogdog
that is mentioned, you really needed to know what is the current draw under load to find out what size of the power supply you needed.... and building an old PC power supply might be the cheapest route... Amazon / Ebay have some used high amp SMPS but stay away from generic brands... I think Meanwell brand is pretty good despite it's COO.
Here is a kicker... by the time you mess with and find the proper power supply... it would have been cheaper just to get a proper electric hoist, unless its your pet project you just like to tinker...and throw safety out the windows....
HF sells the 800# 120V ones for about $100 and the 1400# ones for about $150... there is some safety differences between an electric hoist and Winch... so... converting a winch to haul stuff horizontally might not be the best choice. $$ wise or safety wise..
if you insist getting a transformer base power supply at that high amp... you'll probably going to spend 2x more to get the transformer that can handle that current. Unless you find surplus... which those are getting extinct as well...
wyliesdiesels
Modesto, CA
you need quite a few parts to make this work.
transformer, converter, etc
easiest is a deep cycle battery and battery charger
dogdog
https://www.harborfreight.com/search?q=hoist
Not going to be your nanny or safety Nazi, but as long as you are aware...
Can you use a winch as a hoist?
Can a winch be used as a hoist? Generally speaking, no. It is not safe to use a standard winch to lift loads up off the ground, as it wasn't designed for this purpose and there is a risk that the load will be dropped. One of the key differences between winches and hoists lies in their braking systems.
Millwrong
Canada
Impossible. I'm sorry, but I won't pussyfoot around here. If you're looking for a 120V p/s that'll supply a 12V winch operating with any type of load, you're out of luck. Its just not going to happen. Either run it from a car battery with some decent gauge cable, or buy one of the 120VAC hoists that the Chinese-resellers have for offer.
D
Don1357
Palmer, AK
Oh how I wish we had a harbor freight...
I figure I would ask and see if there was a sensible way to use what I have in hand. I think I'm going to try to source a chain hoist mounted to the same setup I was going to do the electric winch, I beam and beam trolley.
dogdog
Northern tools, sells a version that is the same copy. for few box more.
Tractor supply also I think...
Amazon/Ebay/walmart also sells a generic copy that work off 120V as well
https://www.ebay.com/sch/i.html?_from=R40&_nkw=electric+hoist&_sacat=0
Either case, just evaluate your options before proceeding I guess.
TractorJeff
Elkhorn, WI
I have a 3500lb SuperWinch sitting on the workbench that I just rebuilt the Controller. Their Website stated 132amps at 3500lbs. Apparently they don't design these for max pull longevity because the Relays I replaced were rated only for 80 amps. :lol_hitti
mc4life27
I have a 40 amp bench power supply I could sell and it would power it. But yeah the break is and issue.
Dustball
Hudson, WI
Problem solved-
Hand winch for $30-$40
****** block for $20-$30
Mount the hand winch on your mast and hang the ****** block from the end of your boom to redirect the cable from horizontal to vertical.
Total price less than the cost of a DC power supply capable of the amperage needed for a DC winch.
