signcrafter
- Joined
- May 9, 2012
- Messages
- 12,563
We moved into our house two years ago and the electrical service had been upgraded to a 200 amp service at some point. The only grounding or bonding(I may not be using these terms correctly) is a solid copper, guessing 6 gauge, that goes from panel ground bar to water meter. No ground rods or anything else. I'd like to get things up to par so wondering what all I need to do?
I'm guessing I need the two ground rods. Only issue is my panel is in the middle of my house basement and the wires from the meter to the panel run in conduit. So if I need ground rods my choices are to drill a hole in the concrete floor and pound them down in the middle of the house and run the ground wire just above the concrete floor from rod to rod. Or, run the ground wire out of the panel and over to the outside of the house and put the ground rods out there. Either way is fine with me, only factor would be cost if I put the rods outside since they would be about 40' to 50' of wire from panel to outside by the time I go up and over and down. Bare copper adds up fast.
Is my wire going to water meter good? Or do I need to do anything with that? And then what about the gas line? Can I bond that to the water pipes or is there something else I need to do? Anything I'm missing? I'm in Iowa if that matters. Thanks
