Between 485 & 705 SQ/FT Mid-Century Moto Mecca Makeover
Justind97
Ottawa, Canada
I'm expecting him to find a set of dentist tools complete with the ultra quiet compressor and more tooling than he can use in a lifetime for $100.
I have a dentist drill and accompanying bits, it's not as great as I was hoping.
The bits are so fine and so dainty. It is definitely perfect for my intended purpose which is to port 125cc 2 stroke cylinders and adjust their port heights.
The Foredom does the grunt work of the porting.
Make sure you get the foot pedal, and one with a pre-mounted base would be great. There's enough torque in the motor that if you have it on a table not mounted, when you hit the foot pedal it will roll over.
There's also a base with a dial for max output. Great with the foot pedal My dad has it and it's awesome! :rocker: Mine is not mounted. Needless to say mine moves.
sakurama
Portland - the cool one.
Are you using an aftermarket receiver with a rear tang? I don't know if a receiver with a rear tang can accomodate this, but some people drill the rear of the receiver with a 1/4" hole in line with the barrel so the gun can be cleaned with a rod from the rear by dropping the bolt. I never went that far as I just use a bore snake or drop the rod in from the muzzle, then attach a swab.
10/22s can be taken in so many directions between tacticool and precision. Although a bolt gun is a lot easier to make accurate. My Savage 17HMR is as accurate out of the box as my 10/22 and cost 1/4 as much. But we don't play with guns because we are smart with money do we?
I'll get into that in the next post but it blocks that option. I don't clean my guns with a rod anymore - at least the 22's. Ben got me into using a bit of string trimmer cord that you flat on one end to pull a patch through. On the Pardini you can't use anything other than a patch and you can only pull from breech to barrel end - same for the Anschutz.
I traded my target 1911 (plus cash) for this Anschutz 54 which was owned by a local club shooter. I wasn't shooting outdoor competitions anymore so the 22's seemed more interesting. To me the Anschutz is the end of the game for 22's - a single shot, bolt action 22 with the lightest trigger you've ever felt short of a free pistol. So in building the 10/22 this is sort of what I'm going for. Also, I'm digging my new bench light. Dang.
The top one is a Walther LGM-1 competition air rifle. It's as heavy as the Anschutz and maybe even better looking.
Clearly I have a type.
Gregor
rk_tek
Bella Vista, AR
I've never shot an Anschutz, but I have dreams... The stock on the Walther is a beautiful design. there is only material where it is needed. Almost reminds me of an electric violin.
quadrcr87
Travelers Rest, SC
I also have a 17HMR Savage and it is as accurate as I will ever need. For some reason that doesn't stop me from wanting a 10/22 though.
rk_tek
Bella Vista, AR
22LR is cheaper and that makes emptying a 25rd magazine in a hurry a lot of fun. The 10/22 is a lot like a Jeep. They're 'ok' when stock, but don't excel at anything. When you start adding the aftermarket bits is when you get a gun that you really like. Everything from an pretty lightweight pack rifle(more so if you get the takedown model) to a AR style platform that is cheap to practice with, or a very accurate bench gun.
sakurama
Here is the completed front takedown screw and bushing.
My hope is that by fixing the lower flange (the top hat section on top) precisely into the bottom of the stock and the machined recess into the receiver I will create a solid and accurate fix between the receiver and the stock in the front.
I bought a couple of inexpensive, hand made milling vises years ago to use as simple vises to hold parts when drilling in the drill press - something they've been useful for but not designed for. This is actually what a milling vise is for - milling. By being small and precise it can be held in the larger jaws of your main vise and allow you to hold parts in a way that isn't possible otherwise. In this case the long receiver can be held vertically while I machine the slot for the tang to fit into.
This is pretty hard to see but the shaft here is holding a reverse countersink. The arm extending in is a magnet tool that I'm using to hold the bit as I feed it onto the shaft. Because of the design of the receiver the only way to countersink the screw that holds the tang is this reverse countersink that you lift up.
Doing all this to the numbers makes for a very, very tight fit on the tang. I was still seeing some light when the tang was tightened and realized that the receiver is actually an imprecise casting and that there was a high spot that prevented the tang from being snugged down. I few strokes with a file and it was flat.
There's a lot of calculations to get the tang on correctly, to get the pillar the right height and to open up the stock the right amount to fit the tang. Each one relates to the other and I've been doing a lot of double checking. The receiver, the part that I'm working on, is the part of the gun that has the serial number and as such is "the gun" as it were. If I mess this up I don't have a gun anymore and would have to buy a new part which means all the paperwork, background checks and stuff - not a big deal but a lot of hassle and expense for a math error.
To hold the stock I made a block of baltic birch the size of the receiver to allow me to clamp the stock in the vise and because of the shape I'm having to hold it a bit higher than I'd like. The right thing to do would be to move the vise to the end of the table so I can hang the back of the stock off but that means a LOT of retramming. So I make sure it's good and tight and then machine a 5/8" slot into the back of the stock to allow for the tang.
So far so good. I needed to machine a bit of wood from under the front of the receiver to get everything to lay flat but it looks good.
The rear tang is held by a embedded insert. Kidd gives you one but it didn't look very strong or have much engagement so I bought a few different ones. I'm using centers taps and cardboard shims to hold the tang in place and drill the hole. My first attempt didn't go well.
For some reason, despite my best efforts, the drill wandered off center. Or the stock wasn't perfectly vertical. I wasn't happy with the threaded inserts and gave up and just over drilled the hole knowing the epoxy would hold the insert.
Now to the actual "bedding" part. I have containers of PC7 but in the gun world Devcon 10110 Epoxy Putty is considered the best material. I want to limit the experimentations so I bought some. You can see the receiver is now packed with white clay (thanks Lucas and Nadia!) so that the epoxy doesn't get into any recess. If there's any indentation or recess in the receiver the epoxy will conform and create a "lock" on it preventing removal. Bad. The other thing you do is coat the receiver with clear shoe polish as a release agent.
Devcon 10110 is mixed 9:1 by weight making it different than anything I've worked with before. I don't have photos of the application because I didn't want to get my Leica sticky with epoxy - dusty I can handle, dirty I can deal with but a sticky Leica is a bridge too far.
I'm only putting epoxy on the back end of the stock and in the rear tang area and then under the front stud. Basically reinforcing the two connection points with a new, custom made bed that they will precisely rest in - a perfect fit we hope. The Festool clamp is holding the rear of the action down because right now that insert is floating in epoxy.
It looks and feels like a hot mess at this point. I've covered the stock with tape to prevent epoxy from squeezing out all over the place and made a dam of foam under the bottom of the receiver to help keep that clean. This is when I discovered a mistake in my machining. The front stud that I made had rings to hold epoxy but I didn't create any relief or cut outs for the epoxy to escape when the stud was pressed in. My fits were too precise and the stud basically hydro locked when I pressed it in. I was worried about trying to take it apart so I just kept steady pressure on it hoping it would slowly squeeze out the epoxy and make the right fit.
Twelve hours later I took out the bolts and pried the receiver out. It was I would say a 95% success. The front stud did not make complete contact to the receiver but the epoxy did create a solid bed. It fits perfectly despite this and the lockdown is extremely solid.
The last thing to do was to use a ball end mill to clear out any spots that the barrel touched the stock. This will "free float" the barrel letting the bedding do the work of holding everything in place. The barrel clamp on the front is now just a decoration.
The only thing to do now is take the gun to the range and see if it shoots better than the 1/2-3/4" groups it used to shoot.
While a true test would be at 50yds I only have access to our clubs 50' range but the groups, the lower circled groups are 10 shots and the upper three are five shots, are pretty impressive. It's grouping less than a 1/4" (measured center to center) at 50' and considering that the barrel and trigger are both stock, the whole gun is in fact still stock, and the only change was the bedding of the action, well, I'm pretty pleased.
Total cost of parts is $25 (although epoxy was $40!) and while it was a bit time consuming it was certainly a fun process and one that I'll be able to improve on for the next stock. While Lara's 10/22 is no longer "stock" it's sort of better in that it's a complete sleeper.
I can't wait to get the next one going and see if there's improvements to be made with a better barrel and trigger and to fix my mistakes on the bedding process. Then I need to find some cross country skis!
Gregor
slik560
Kansas, USA
Hmmmm.....metal fabrication and woodworking within the same project. I think you have found your true calling. Well done, young Jedi.
bdbecker
Iowa
I know the whole point of the project was just a test run for bedding the receiver, but reinstalling that factory barrel band after bedding the receiver and floating the barrel is kind of counterproductive. I'd bet you see those groups tighten up even more if you removed the band. Cutting off the stock at the barrel band line actually yields a nice looking stock, not that I'm trying to add more to your "to-do" list.
rk_tek
Bella Vista, AR
Another good looking project. I found out how imperfect the casting of the receiver is when I decided to polish mine. I started working up through the grits on a sheet of glass and the sides started looking like a topo map. The polished receiver was impossible to keep clean and I ended up 'engraving' (scratching with the tip of an exacto knife) a diamond weave pattern. If I do any more work on the gun, I'll probably paint it Rustoleum smoke gray because that's what I paint all my tools. And a gun is a tool.
rk_tek
Bella Vista, AR
I'm betting the barrel band has been clearanced so it doesn't touch the barrel any more. I do agree that an angle cut just behind the band step makes for an attractive and budget friendly stock.
jdp993
A great series of posts on gunsmithing.
Other than summer camp never had much of a chance to shoot. But, 40 years ago in college I earned tuition money installing digital readouts around New England. One of the places I did this was Sturm Ruger in Newbury NH. The guy who ran the tool room there was a super talented machinists and just a natural engineer. I still look at gunsmith work as mechanical art.
Its interesting that you have both an interest in watches and guns as I have always seen them as closely related from a mechanical art point of view. As with all your work, a great presentation of what you did. Good inspiration for everyone who reads it.
sakurama
Yes, you're right, if that barrel band touched the barrel it would throw things off but when I clearanced the front of the stock I removed the section of the stock that serves to hold the front of the barrel up against the band and that allowed the barrel to drop down so that the barrel band isn't actually touching it.
I tried to get a shot but you can't quite see the gap - it's between 30 and 40 thou. I thought I was going to have to machine the barrel band so it wouldn't touch the barrel but I got lucky and the barrel dropped enough that it's free floating. The band is merely clamping itself to the wood forestock so that it looks like it's stock. Keeping the sleeper vibe going.
Gregor
sakurama
I feel like there's a common thread. When I was younger I used to say that I liked anything that spins or points. Fans spin, guns point and watches do both! I suppose that still holds.
Gregor
bdbecker
Iowa
Yes, you're right, if that barrel band touched the barrel it would throw things off but when I clearanced the front of the stock I removed the section of the stock that serves to hold the front of the barrel up against the band and that allowed the barrel to drop down so that the barrel band isn't actually touching it...
I should have known better... never underestimate The Gregor!
Cypress
Colorado
Excellent write up Gregor and looks like you have yourself a shooter there.
The world of 22's is vast and extremely interesting to me. I've been a member over on Rimfire Central for quite some time. That forum is the GJ of 22's! You are most likely already aware of it, I'm sure.
I've built several rifles over the years in various calibers but I always find myself coming back to the simplicity of 22's. There isn't a rifle in the safe that gets more use than my Rugers.
Looking forward to your next build.
Prometheus
Gregor
I'd go a step further - it's mechanical inquisitiveness/curiosity. Watches, firearms, cameras, fans, motorcycles, machinery, adventure van, audio equipment, it's all got a "gee wiz, how's that work?" vibe to it. I'll admit I feel the same way - it's all cool stuff and I want to know how it works, and it's also why I have multiple mechanical watches, firearms, cameras, vintage machinery, and some new-ish medium-fi (technically low end Hifi, but I'm too cheap for the good stuff).
Now if you can figure how how that stuff goes with lawn care and goodyear welted shoes we might have a unified theory of manly cool-stuff.
Edit* Oh, if the Foredom rabbit hole goes too deep, look at Proxxon rotary tools. Once I got one my old dremel went straight into the trash. So much nicer than any dremel I've ever used, and not terribly expensive either, at least compared to Foredoms.
Dr Klaun
Tumalo
I was going to ask if you Nordic ski? Biathlon is a fairly limited opportunity sport. Most resorts won't touch it due to the liability. It has been on my "must try" list for a long time.
elvee
Atlanta, GA
My son's birthday is 10/22 and I have been planning his (probably) 10th birthday present for a while. Somehow I think the cost of that gift has gone up a bit.
rk_tek
Bella Vista, AR
Some areas have ‘summer’ biathlon where you run, bike, or even skate between stations. Usually if it is biking the guns are left at the station and you ride a loop back to the same station because of the higher likelihood of crashing. I can see Gregor tarting up the dirt bikes and starting his own motorX biathlon.
sakurama
I found a good deal on ebay. I'm down the hole dammit.
No, I did when I was a kid. Until I discovered this thing called a "ski lift" and that pretty much spelled the end of that.
Dang, that would be one heck of a gift. It was two summers ago maybe, I've lost track of time with this year, that I got Lucas and Nadia an air rifle. They still can only use it with supervision but they really love it. It's a great way to start with the ability to shoot in your yard if you don't live in the country.
Ha, there's a local club, the Sang Froid Riders Club, and they did a version of this:
It involved costumes, BB guns and a fair amount of beer. Scott and I did it a year ago? Again, no sense of time but obviously we're not wearing masks, everyone is happy and we're with other people so clearly BC. I'm looking forward to AC and getting to do this nonsense again.
Gregor
E12-535iTurbo
The Netherlands
This as a European seems to me….. like a different culture. No, make that a different world.
Riding, drinking, guns, a big knife on the table. All kinds of wrong.
Giving a 10 year old a gun for his birthday….
It will soon be illegal to buy a knife under 18 here in the Netherlands. Talking about a different mindset / mentality. Not judging, just noticing. I do love the engineering work to improve a tool though! Thanks for sharing Gregor and all the others. It's fun to get a peek into another culture.
locul
Hmmm. Its like your projects are off in more clean way. Mine seems more dusty, which of course gets hosed by the danish Christmas rain. Hoho.78f18c655de1645a9323a36d330b5ed6.jpg707654cbf5f64fe2f16860297c096254.jpg
Sendt fra min SM-N975F med Tapatalk
gasgas17
Nova Scotia, Canada
Interior brick walls. Man that has to **** when you renovate. I am very thankful we live with an abundance of softwood trees. On the flip side your homes must be very quiet with all those brick walls.
elvee
Atlanta, GA
It is a different world, and one that is divided even within itself. While I enjoy shooting, used to hunt, etc my views on guns are quite a bit different than a lot of other enthusiasts here.
And to be clear, anything my son receives will be in the vault unless he and I are taking it to a range. I will get him started with a pellet gun to teach safety, handling and technique. Pls I can build a range for that in my backyard.
sakurama
I think elvee's quote sums it up well - it is indeed a world divided in itself.
And to be clear, that photo and that group are absolutely all kinds of a wrong in one photo - even Scott and I were surprised but that is a group that enjoys putting on events that skirt common sense and rules. But all riding was off road and despite my angle (I wrongly got in front of the "firing line" for that shot) people were pretty safe and they were just kids air rifles - barely able to shoot 50' much less hurt someone.
To me the idea of a knife being illegal for a kid under 18 is just as crazy as being able to buy a gun with no background checks. I find that as I get older I see how difficult it is for people to have moderated and considered views on complicated subjects. It's much easier to have a simple and dismissive view than one that considers the all the complexities.
It's part of why, although I've been a competitive shooter for almost 10 years now and it's a big part of my personal life and group of friends, I've never broached this here. At this point you guys know I think a lot about things and am careful and respectful of my tools so it seemed like a good time to show the work I was currently doing - in the garage!
So thanks!
Gregor
sdistc
Helsinki
... and my ideas and the hardest part of this is how to resolve all the areas where the boards join at right angles and how to minimize that so it looks clean. Plus how to attach the rail and all that. And how to redo the closet under the stairs...
Funnily enough, I just watched a YouTube video from a Boston-based construction company, NS Builders, breaking down their use of mitre cuts to ensure a seamless grain on the oak stair treads (as I have too few posts to hotlink, the video is entitled "Custom stainless steel & white oak stairs leading to Boston roof deck").. perhaps this could be an idea to appropriate and adapt for your needs?
Loving the constantly varying rabbit holes here, by the way :D
Stopwatch
I think elvee's quote sums it up well - it is indeed a world divided in itself....
...I find that as I get older I see how difficult it is for people to have moderated and considered views on complicated subjects. It's much easier to have a simple and dismissive view than one that considers the all the complexities....
I've been reading about the "overview effect" astronauts often experience. From the NASA website:
Unless you spend a lot of time looking at images from space—a pasttime that was in its infancy in the late 1960s—the view can be mysterious and disorienting sometimes. Reading through the transcripts of Apollo 11 communications, we can get some sense of the wonder, disorientation, and awe that Buzz Aldrin, Michael Collins, and Neil Armstrong must have felt while looking for navigation points or for simple beauty shots of their planet. About 51 minutes after launch, the conversation centered around lights in Earth’s atmosphere:
Collins: Look at those bright ones down here.
Aldrin: Lightning! Is that lightning out your window?
Armstrong: No, I haven't seen any lightning.
Aldrin: Hell, that must be lightning. Either that or it's the atmosphere.
Armstrong: I just saw something. Maybe it is the atmosphere. They said that Borman's [crew] could see it. They couldn't hear it, but they could see it alright.
About 30 minutes later, Collins looked down on a different, unfamiliar scene and noted: “It looks like trees and a forest or something. Looks like snow and trees. Fantastic. I have no conception of where we're pointed or which way we are, but it's a beautiful low-pressure cell out here.”
Ten hours into the flight, Aldrin and astronaut Charlie Duke (working communications from Mission Control in Houston, Texas), had a conversation that sounds like a description of the images above.
Aldrin: Hey, Charlie, I can see the snow on the mountains out in California, and it looks like LA doesn’t have much of a smog problem today.
Duke: Roger, Buzz. Copy. Looks like there’s a good view out there then.
Aldrin: Charlie, with the monocular, I can discern a definite green cast to the San Fernando Valley.
Duke: How’s Baja California look, Buzz?
Aldrin: Well, it’s got some clouds up and down it, and there’s a pretty good circulation system a couple of hundred miles off the west coast of California....Okay, Houston. You suppose you could turn the Earth a little bit so we could get a little bit more than just water?
Duke: Roger, 11. I don't think we got much control over that. Looks like you'll have to settle for the water.
We're all more connected, and interconnected, than we realize. My feeling is our differences are largely meaningless most of the time. Brick walls or wood framed walls? Firearm ownership? Italian 90 degree V-twin or American 60 degree V-twin? Miller or Lincoln? Griswold or Wagnerware? It's all fine with me as long as we can respect each other and each other's considered and thoughtful opinions.
gearhead1960
Gregor
To some people it's either black or white. No in-between. That is sad as nothing is ever black or white. Just like voting strickly by party line. I've voted in every election since 1978 and while I don't always agree with each candidate, I also don't always disagree. I weigh what they have to say and vote based on that. Sometimes, it's the lesser of 2 evils. Other times, it's what issue is most important. Just my 2 cents...
zanyad
NE Ohio
Here’s the link:
Whoah. Just watched this video. Super cool! :rocker:
sakurama
I've been reading about the "overview effect" astronauts often experience. From the NASA website...
Dang, heck of a first post. Thank you and welcome.
I think you're very right. There's so much we just don't know about how what we do effects the world. Some things ripple out and make waves of change and they can bounce back. Without going too deep you're absolutely right - we are much more interconnected than we realize.
Also, those stairs were amazing. My commitment to using the fir flooring to try to blend the stairs into the house but also keep the aesthetics of the design - it's certainly complicated.
Gregor
Stopwatch
Dang, heck of a first post. Thank you and welcome....
Cheers on the welcome; what, one post in nine years is less than quota?
Rider of titanium bikes and carbureted Ducati 900sses, restorer of a house, constructor of another, designer and builder of furniture, architect, fixer of things - maybe there was a polar pull to lurk about your exploits? Funny how this interweb thing works sometimes.
I do draw the line at simultaneously drinking beer, riding motos in pajamas and shooting. A guy's gotta have standards, after all.
ayer
Adirondacks Northeastern NY
Something I do on all Ruger's with the barrel band is slightly ( very slightly ) releve the area so it does not contact the barrel itself. This may not be an issue as you bedded the rear also. Great work as always.
Ted
sakurama
So one of the hassles of the way we're working now is that we haven't really changed how we work despite changing how we work. For instance, editors still want to approve each and every shot but they're no longer sitting on the couch in the studio. So we shoot a photo, send a screen capture and wait...
I've found dimpling a pretty good way to wait.
I liked the grooves that I cut in the forestock and I planned to paint them black like the grip area but I kept thinking that the texture, the visual signal of "grip here" needed to carry through. So I decided to do it.
I love finger grooves too. My target pistol fits perfectly and part of that is that fingers have a place and the grip tells you exactly where that is. Will it fit everyone? No. But then that's the fun of it. It's not as singlular a fit as my Pardini pistol but it feels perfect right now. I also love the look of defining the grip area. Note: see that little tiny corner on the heel? I accidentally banged it into the sanding belt while trying to narrow the big blocky back of the stock...
I don't get to use the digital height gauge very often but when it's needed - like to mark the center of the receiver here - it's pretty helpful.
Still nerve wracking but the numbers were easier this time.
Here's a shot of that reverse countersink bit.
I made a taller and thinner lug this time so I can be sure it will seat and engage.
I'm using the notes from last time but I'm running all the numbers again to just be sure.
I really love the light over the bench. It just makes things look better. It's odd that I make light for a living but didn't think it was worth the trouble until now to make nice light over my main work area. Good light is like a good chair - you never think about how uncomfortable you are until you're suddenly not.
Still struggling with the color balance of all the shop lights but I'm getting closer. I wanted everything to be daylight so I wasn't dealing with such strong orange/blue contrasts with the daylight even though I often liked that. It's a bit of a shock to go from the warm house to the cool garage but after a few minutes it's normal. Life was easier when we just had one kind of light bulb.
Gregor
E12-535iTurbo
The Netherlands
Just to make sure: There is no judgement here. I understand the complexity and as I wrote, appreciate the peek into another culture. It's like travelling but behind a desk/computer. I definatelly did not want to start a political discussion on arms.
Thanks again for sharing.
Choirboy
SE Iowa
Start a political discussion on arms? Heck, you didn't start it, our country has been having it for years, decades. And that is the problem: it has become a political discussion instead of an honest discussion of logic and trying to understand competing points of view. Once it became politicized, all opportunity for intelligence was removed, and all that is left is ignorance and vitriol on both sides.
slik560
Kansas, USA
The level of craftsmanship demonstrated in the whole refining process for the rifle reminds me why I use a gunsmith. My precision DIY days are long past....if I ever HAD any. :) Well done. I need to scroll back and review the lighting setup. It really does work well.
elvee
Atlanta, GA
Gregor, you now have me considering talking to my production lighting guys about what kind of lighting to install over my bench. The support system won’t be an issue for me, as I think you know.
