TheEquineFencer
I just woke up and came up to the shop.
I just did as I said I'd do.....I went back and bought 4 more tonight as I said I'd do in another thread.( Harbor Freight 4 Foot, 5000 Lumen Braun LED Shop Light?)
The Winterville, NC store was out, so I went to Goldsboro, NC store. I did as OccupantRJ suggested, I looked up the stock number, checked availability and called before I went....then I asked them to hold 4 for me. LOL, the guy said they showed 172 in stock, but he'd "hold" four for me in case they sold out before I got there!
I plan to use them in some "unconventional ways"....who knows how they'll hold up. I plan to power one and see how it likes a Vanner 300W pure sine wave inverter. I plan to install it inside of an outdoor "run-in shed" for the horses. I'll use a rotary mechanical timer wired to the remote on/off circuit to turn the inverter on/off and leave the inverter switched on plugged into the HF 5000 Lumen light. I guess I need to figure out how long to safely run the inverter without "smoking" the battery as it will need to be charged every so often. The Light says 1.1A draw. I'll see if I can figure out what the inverter will require. That'll determine what/which battery/batteries I'll use.
It'd cost a small fortune to run a 15-20A circuit to the building. and I Really do not want to take a $300-$500 set of Solar panels and MPPT charge controller I have to just keep a POS battery charged so she can see how to pick up "road apples" in the dark.
Here is what I know and don't know. The HF light has a nameplate power usage of 1.1A @120VAC, that's 132W. The inverter runs at approximately 89% max efficiency. It consumes 0.15A while the remote is energized. I guess it's time to go buy an AC/DC amp probe. I have a few 300W continuous duty, 400W surge rated Vanner brand Pure Sine Wave Inverters I plan to power it with. The inverter has a remote terminal I can switch it On/Off. I plan to leave the inverter switched on, with the light plugged into it switched on. I have a mechanical remote timer, (1 hour), in place already I'll wire to the remote circuit to turn everything On/Off. I'm "guessing" at best, it'll draw 2Ah from a battery if it runs a hour. From timing my G/F, she might use it 20-30 minutes per night if she's late feeding the horses. But Let's figure 1 hour per day usage.
Low voltage shutdown is at 11.5 VDC preset inside the inverter. The battery will get scheduled to be recharged on a regular basis.
How many Ah battery do I need minimum? I'll use a standard type Flooded Lead Acid. I'm guessing I need to stay around a 70%-80% State of charge for the battery to last a while.
I hope this thread incites some others to "think outside the box."
) listing of 0.5 amps. Same as the screenshot of the manual. I just measured one (yeah, I bought a couple too
