I have painted gallons of Imron, sometimes in the same day. I never use any pre treat and very rarely use self etch. If I want it to last it's epoxy primer with Imron on top.
Here is the thing about blast,,, and etch primers are the worst actually,,, but blast leaves peaks and valleys. The valleys not a problem but an etch higher than about 220,,, or blasted has peaks and if a guy looks with a glass or scuffs it off can see the primer run right off and see peaks poking thru, clean thru.
So, sandblast and scuff a couple passes with a maroon brute, it cleans the sand and smooths off the peaks, feel the difference, makes it last. Blow dust off and spray.
The thinners are specific to Corlar and Imron.
