Running elect to a sea container
bmxdukie
Ontario, Canada
Hi folks. I have a 100 amp service in my back garage.
Over the summer i build a sea container lean too for storing my tractor and firewood.
How would i go about putting electrical out to the container.
My panel is on the opposite side of my garage. Ive finished and drywalled inside and have vinyl siding on the outside.
The container is about 30' from the garage.
Any thoughts?
dcg9381
Austin, TX
Here, I'd just trench it, PVC conduit, and run 6 ga wire to a Siemens Talon sub panel good for 50 amps or so (This panel comes with 3 circuits, 3 outlets, 3 breakers, plus spares).. Mounted at the location of your choice. Given, it might be considered a "separate structure" and require it's own ground, but at 30' away, I'd treat it like I do a pad for an RV.
larry_g
oregon
How much power do you want in the can? Makes a difference if your thinking 15a for some lights vs enough power to run a woodshop or such with motors and heater/air conditioning.
lg
no neat sig line
sberry
Brethren, Michigan
I would run a circuit. If I was going to invest in solar would put it somewhere it would get utilized. If it was utility there is a chance it could be an extension. 20A service is a benchmark. Part of a good structure is to have the utilities plumbed to it.
