Upside down electrical outlets?
cowboyjosh
Alright, I don't know if anyone brought this up yet.
When I wire a house, its ground down, UNLESS the outlet is a half hot controlled by a switch, then the outlet is mounted ground up, that way the homeowners know that is the outlet / outlets controlled by a switch. In Colorado and Arizona I find this to be the case in many newer homes, some local AHJ's now require this type of install to be able to identify the switched outlet.
Rickster55
Syracuse, NY
Okay, according to my electrical code (the one I just made up), you MUST install outlets ground side down (sorry, I like smiley faces) and you MUST use electrical tape to wrap all contact points. Oh, and by the way, (before anybody asks) the tape should be wrapped clockwise. :beer:
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Yeah, -but what COLOR tape should you use? RED since it is covering HOT connections? Or alternating RED/WHITE tape also known as PINK since one side of the outlet has HOT screws and the other side has NEUTRAL? Another option would be alternating BLACK/WHITE tape also known as GRAY since the BLACK wire is usually the HOT connection? Or should we be required to carry both types so that whatever color wire is used to supply the HOT terminals we have the proper tape to apply? What do we do with outlets that are wired one end from a switch and the other side always HOT? Would we need to carry TRI-COLOR tape? Would we need to carry RED/BLACK/WHITE tape as well as BLACK/RED/WHITE tape since we always have to wrap clockwise? Alternating color tape would have to be wrapped so that the proper color was on the proper SIDE/TERMINAL of the outlet. If we must use alternating color tape do they make it in different stripe lengths to cover different outlet sizes? Or are we just supposed to stretch the tape to length for the particular outlet used?
BioHazard
I think rather than WRAPPING the entire outlet in tape, you should use red tape on the hot side, white tape on the neutral side, and some blue tape on top and bottom just to give it a patriotic feel. (and cover up the part where it says made in Mexico)
Poncho Villa
Oklahoma City, OK USA
Blue tape would not match the green ground screws tho... :lol_hitti
Using Red, White, & Green tape colors you not only take care of matching the ground but you also do not need to cover up "Hecho En Mexico". :lol_hitti
PassnThru
Bowling Green KY
Clear tape must be used to allow weekly inspections :thumbup:
JamieK
Winston-Salem, NC
Umm, heres a simple solution. Just always use two prong outlets like these
istockphoto_3662773-two-prong-
and just cut the ground prongs off any electrical cords. :thumbup:
Couldn't get much simpler than that.
PassnThru
Bowling Green KY
Not so simple. Now the argument about the neutral being on the left or the right will commence. No solution is so simple that it cannot be over-analyzed :)
BioHazard
Cut the hot slot a little longer. Now it's got dual polarization. :thumbup:
ddawg16
S. California
Problem solved.....any quesitons?
And on a semi-related note.......you can never have enough outlets.....I don't run everything at once....and the pic is during a 'low use' day.....I just don't like having to plug and unplug stuff.....besides, keeping cords plugged in keeps the saw dust out....
So....for anyone planning their electrical....LOTS of outlets....it doesn't use any more electricity if they are not used.....
babzog
Eastern Ontario, Canada
Old cords and appliances like refrigerators were made with the ground pin up to lay flat against the wall. Newer cords are made for "happy face" outlets and the ground pin is down. If I am wiring for an appliance I wire the outlet so the cord lays right.
Does anyone make a welding plug with the ground at the cord end of the connector rather than the far end? Unless I raise the box and force those #6 cables to bend more, I'm forced to plug the welder in with the cord approaching from the top which puts stress on the cord/connector junction.
