Drain Clean Out - TIGHT!
Shiftless
East Bay SFO
I would start by carefully chipping away some of that mortar around the fitting. That might be interfering with progress.
Then grab a bigger wrench. What are you using up to now?
Heating the plug makes it expand which is moving in the wrong direction. But it might be good for breaking loose. Maybe heat and then cool it down before more twisting. Good luck. If something breaks behind the wall, you’ll be in for a lot of work.
allinon72
Indianapolis
Looks like it's from the 1700s. :shocking: Is it possible that it's mortar'd in? Hard to tell in the pic. Anyway, I'd put a big pipe wrench on it.
Bert_
NW Iowa
Put a big pipe wrench on it. Use a cheater bar if you need to. It will either come out or the hex will twist off. If that happens just use a chisel to work the rest out.
unslow1
Illinois
Whatever you decide to try you better be in a position to deal with it if it breaks. That could get real ugly real fast.
You could call a plumber and get a wallet clean out as well.
steves_001
Southern MN / Northern MN
Use a chisel on the edge in a few places to get it moving. Be prepared to break it out and install a new plug. I've had success with the chisel on a 45deg angle or so around the circumference in about 4 places or so. (lefty loosey) Hopefully that makes sense?
Captain Spaulding
Southern Indiana
I’d be hesitant to apply a lot of force without looking at the pipe on the other side and maybe putting a wrench on it to isolate the torque to the plug end of the pipe. You may do some damage if the pipe turns before the cap.
BillK
Beautiful Southern Maryland
Are you sure it is a clean out ? Looks awful small if those are normal size bricks.
I would have to chip away the mortar to make absolutely sure that it is a threaded fitting.
If it is definitely a threaded fitting I would get it as hot as safely possible and then spray the PB Blaster on it while still hot. That might help.
BD1
north side
I say that's Brass. Drill hole, use sawzall to remove big pieces, then chisel to collapse plug threads to inside. Brass is soft.
nadogail
Coronado, CA
Spray it with Liquid Wrench, Rap it with a hammer, get a cup of coffee, put a strain on it with a big wrench then repeat as necessary. The vibration from the hammer blows may help the penetrating oil into the threads.
Stuey
28m above sea level
Good luck, and whatever you try, don't do anything until Monday just in case you need to make an emergency call to the plumber.
PCustoms
VT
No suggestions from me, but if I ever build a brick or stone wall I'm going to grout in a big *** brass clean out just to mess with people.
nyy845
CT
Try using an impact on it at a low power setting. Just let it hammer away for a long time.
I've gotten a few off using this method; as stated, don't use the highest setting (unless you want it broken off).
