we'll have to see if they "solved" the back drag vs. tooth count issue
My Vessell TD-6700W-23 stubby ratchet arrived last night and here's my first impressions. You cant use the typical euro and usa 25mm/1 inch hex bits. Vessel's hex socket is much deeper than normal, you could use those hex's but it barely sticks out and you'll need a tool to pull it out;
Should I cancel my order on the 36 tooth Zeal, and wait for these new ones?
Do you have a Wiha ultra driver (26-in-1) or Festool/Wiha Centrofix by chance? I wonder if those bits will work in the Vessel. Wiha for some reason has dropped the ball on a ratcheting variant of Ultradriver, which seems like a huge no brainer to me
IMG_20201212_150403877 by david_edelman_ohio, on Flickr
IMG_20201212_150539260 by david_edelman_ohio, on Flickr
IMG_20201212_150738813 by david_edelman_ohio, on Flickr
IMG_20201212_151042851 by david_edelman_ohio, on Flickr
IMG_20201212_151129136 by david_edelman_ohio, on Flickr
IMG_20201212_151213584 by david_edelman_ohio, on Flickr
IMG_20201212_151313191 by david_edelman_ohio, on Flickr
IMG_20201212_151730262 by david_edelman_ohio, on Flickr
IMG_20201212_151929537 by david_edelman_ohio, on Flickr
IMG_20201212_152052771 by david_edelman_ohio, on Flickr
IMG_20201212_152324805 by david_edelman_ohio, on Flickr
IMG_20201212_151824773 by david_edelman_ohio, on Flickr
Looks like the part no’s didn’t change.
I wonder if that means we'll be able to buy a 72-tooth rebuild kit to convert our older ratchets?
(Fingers crossed...)
About a month ago I decided to find out why everyone is so excited about the Ko-ken Nut Grip sockets. I ordered the small 1/4" set (RS2450MS/6).
Today they earned their keep. I was replacing an A/C expansion valve on my wife's Saab; it's in the middle of the firewall, below the intake manifold. I had to work one-handed, left-handed (I can't even feed myself left-handed), with the palm outward instead of inward, while laying across the fender and engine.
The retaining bolt for the high and low pressure lines is between them, with very little space. I couldn't see the bolt hole, and I couldn't put it in with my fingers because there wasn't enough room around the big (low pressure) line.
Luckily I had the Nut Grip set. I pulled out the 10mm socket, set it on a short 1/4 extension, and easily installed the bolt. I might have been able to jury-rig something with tape and a regular 10mm socket, but this was quick, easy, and sure.
I'm now a believer. I just wish they made a 9mm.
I have been eyeing them for a bit but haven’t pulled the trigger. I know they’ll be worth it. I need to just get them and remove that segment of frustration from my life![]()
Locking pliers that are made in Japan.
Ah I like mine, as well as the set of Kuromaku (aka Shapton) 1000, 5000, and 12000 stones. They are wonderful for putting a razor edge on knives.
Where did you find these? Looks like Amazon.jp, but I haven't been able to find them.
Factory gear website.
https://ec.f-gear.co.jp/item_list.html?siborikomi_clear=1&keyword=KO-KEN +Z-EAL+3/8sq+72ギア
One of their youtube vids looks to go into detail about the new 72t mechanism. I need to learn Japanese.![]()
See a page or so earlier in the thread where we talked about using YouTube's translation/closed captioning to get a little closer to what they're saying.
I had to watch it several times before I could really "get" what they were saying. In fact, I just watched it again and realized at the end they were talking about the 1/4 drive version, which the engineer said he was still working on and for which there was no timeline. Which means the 3/8 in the 1/4 body is a long way off yet.
One of the things I think I got from their conversation was they hadn't done higher tooth count ratchets before because the finer mechanisms wouldn't pass Ko-ken's own strength and durability testing requirements. (I'm not sure, but it seems as though they implied that the Nepros 90-tooth wouldn't meet Ko-ken's standards. A little rivalry between them and KTC?)
Olfa makes some cutters with a locking knob. The Olfas I have are made in Japan and very good quality.
Thanks interceptor but I don't think Olfa makes a low profile all metal 9mm verison (like the NT AD-2P) with a locking dial knob. I only see ones I see with a knob have a larger plastic body? Olfa does make nice cutters.
I love the NT "AD-2P" cutter that you can hold like a drawing pencil, right now its my favorite.
I highly recommend you trying out NT's 30 Degree, Black carbon "BA15P" extra sharp blades. I've been very impressed by there edge and durability and they're economical on amazon. I think you'll be happy with them.
My second favorite cutter is the NT A-400GRP-RD
Ko-ken Zeal!
I’m very happy to get my hands on some 1/4 Ko-ken Z-series stuff!
I really like the low back drag on the ratchet, plus it’s extremely compact. I am very impressed and Koken will see me knocking on the door for more items soon.
Here’s a little unboxing with initial impressions.
-Brando
