This!
If ever there was a tool that needed to live in it's plastic case...or in a dedicated drawer that's kept closed...it's a caliper. One little speck of bench debris in the linear rack gear and you can have issues.
I have a couple of questions. Is it best to store the caliper with the jaws slightly opened or closed? Should I remove the battery after use? Should I wipe the caliper with a light coating of oil before storage to help prevent rust? Any thoughts?
There is no reason to remove the battery when not in use. Mitutoyos have negligible power use when off.
It doesn't damage the calipers if they're stored with the jaws closed.
You do not need to wipe them down with oil, they are made of stainless steel.
The best way to clean the jaws is to close them on a piece of clean paper and pull the paper out.
Always store them in their case.
1) Don’t drop it. Keep it in it’s case when not being used.
2) Don’t get dust or grit in it, or even near it. If you forget this, and do get anything on it, don’t try to use it. Wipe it off first, better still blow it off with an airline.
3) Buy a conventional caliper that you can use in dirty environments, or if you need something rugged. This preserves the electronic one!
1) I did say "don't drop it" in all caps above. I'll add to that that digital calipers are surprisingly drop resistant. They're WAY more rugged than mechanical calipers. Really, their weakness to dropping is the knife edge on the inside jaws. Everything else tends to survive.
As for 2 and 3, I I would suggest the opposite. A digital caliper will always survive better around grit and dirt than a dial caliper. About the only thing that will stand up better is a vernier, but how many among us would prefer to use a vernier?
I remove the batteries of the ones that I don't use often, not to save the battery but to save the caliper from a battery leaking
Hi, I recently purchased a Mitutoyo digital caliper and was wondering if you guys could offer some suggestions about how to care for it after use. I'd appreciate any advice you guys could give!
In general nothing needs to be done. The generic calipers I had about 15 years back did eat the battery when stored. Effectively "off" was just something that turned the display off.
I've never seen this with name brand calipers (Mitutoyo, TESA, iGaging, Sterrett). I'm not sure if this has been addressed in some of the cheaper designs. The answer is simply turn off the measurement part when the display is off. TESA does this as the calipers reset zero every time they are turned on. Many calipers address this issue by simply using CR3032 batteries that last a lot longer with the same "off" power consumption.
I use a #357 battery in mine. It's a silver oxide watch battery. An LR44 is an alkaline battery. The 357 won't leak as an alkaline can, and it has a longer life.
