Thanks Jake! Now to decide if I send the link to the wife to buy for Xmas or just buy it and wrap it for myself![mention]loganb [/mention] [mention]nicholam77 [/mention]
The Massaca jig is now $70 on sale.
https://masscaproducts.com/products...-bit-hex-key-screws-square-driver-stop-collar
Nice work on the fence upgrade! I plan to do the same with my Beisemeyer fence and 80/20 extrusion on my CM 133.xxxx saw.
Nick-Nice work on those saw upgrades! That looks incredibly handy and takes away one of my common frustrations with the jobsite style saws of limited contact area between fence and workpiece. Coupling that with the flexibility and interchangeability with the router is going to be very nice!
That fence looks super boss..nice. I do like the positive adjust/robustness of the material hold down.
Nick every time I come in here I have to give myself due time to read through your great post and study your photos. Always enjoyable.
Bret
That is awesome Nick. That is a great assortment of planes. More than I have. I have avoided the hand tool rabbit hole for a long time.
Bret
Nick, a hand plane was one of the tools almost every household had back in the day. My father's Stanley No. 78 is a USA model and still has the depth stop and fence. My father-in-law's Waltham has quite a few stamped steel parts so I suspect in's from the mid-50s. My earliest memories of the Stanley are of my father trimming the doors in the house we lived in in 1948-52. We now have 9 grandchildren and 3 great grandchildren so maybe one of them will be interested in the history.
I’m been checking out those JessEm guides. You’ll have to give a review after you have used them more.
I love those old planes. I have a few, but need to get better about setting them up and sharpening. Now you need to build a sharping pond and share for us!
I’ve got a small assortment of hand planes in my shop. Two cents: get the block plane razor sharp to start, and keep it handy. I find I grab mine frequently, especially for adding small chamfers and cleaning up edges.
It’s easy to go down a rabbit hole comparing (and subsequently worrying about) steel types and sharpening angles, among other factors. The wood won’t know the difference. The beauty of using a handplane is that the feedback is instant and visceral.
Start with a soft wood like pine. See if you can take a section of 2x4 to 6 square faces.
If you’re in doubt, the answer is nearly always to make it sharper.
Good Job! Keep up the good work.
Are the hold down wheels on the fence spring loaded at all? Just wondering how they do with uneven material? If there is such thing as "bling" for a table saw, you've nailed it..ha.
...I wonder if it is worth it trying to sharpen the old iron it has or if I should just start fresh with a replacement. Either way... it's pretty fun! I do love my power tools, but I've really been wanting to try some hand tool stuff, so this might finally get me going.
I think its worth learning how to sharpen. You'll need to learn eventually, might as well do it on an old blade that you can't make any worse. By the time you buy replacement blades for all of them, you could have purchased a decent sharpening system. Even though they are your Grandpa's planes, I'd consider the blade a consumable - the plane itself is where the sentimental value lies.
Be careful when researching sharpening methods and tools. That is a heavily debated topic with little consensus. Just know that no matter what you choose, someone will be happy to point out that you made the wrong choice.
I think Stumpy Nubs has the best overview on the topic:
I bought a Lee Valley blade for my #4 but it just postpones the sharpening some. I'd buy this: https://www.woodcraft.com/products/veritas-sharpening-system and use silicone carbide (3M Wet-n-Dry) sandpaper, working up through the grits. There are lots of options and price points. This works and is low cost.
My sharpening set up. This discussion motivated me to tune up most of my planes, which in turn prompted a wee project.
Left to right:
- Stanley low angle block plane. Readily available on Amazon for about $50. It took forever to bed the sole in which had a sizeable hollow in it. So I didn’t, and did a cursory sharpening of the blade, and have been using it for about 5 years. This is what I use when there are nails or glue in my workpiece.
- Veritas low angle skew block plane. Inspired by the wood whisperer, I got this so I wouldn’t ‘need’ a conventional rabbet plane. It’s nice that it has a square shoulder for cleaning up corners, but it’s not a feature I use too often.
Or really ever.
- lie Nielsen 4.5 smoother. Cost an arm and leg and weighs nearly just as much. It’s gorgeous, expensive, and like a race car driven on the streets, appropriate and comfortable in brief sprints.
-home made jointer. I made this with a 2” hock blade. Super handy for cleaning up plywood edges before glueing on hardwood edge banding. A pain to adjust. The next ones I do will be with a euro-style screw adjuster. Same for the home made smoother.
Sharpening:
- Tupperware box for storage and soaking the stones
- Ikea plastic shoe tray for sharpening. It has coin dimples so items don’t sit flat in a tray of icky water and sludge
- 6” diamond stone to flatten the water stones. Super critical step that few people emphasize enough. If your stones aren’t flat, sharpening and squaring a blade will be impossible. I flatten my stones with a cursory couple of swipes every time I sharpen a blade.
- 1000/4000 dual stone
-8000 water stone for final cleanup and micro bevel.
- veritas sharpening jig. Easy to set up but more adjustment than I use. I set everything at 35 degrees and add a micro bevel at the end and call it good.
- Pencil to mark the stones as I flatten them
- sharpie to mark the blades to ensure I’m hitting the right surfaces
- fancy lie Nielsen screw driver I bought on a whim. Utterly unnecessary but better than a nickel
- starret 4” mini square for checking blades
- spray bottle for washing things off
- wd40 for warding off the rust
I’ll reiterate, there are a ton of ways to sharpen. Don’t overthink it. Go coarser to fix big nicks, and finer until you can see your reflection in the blade’s edge. If you’re sweating, cursing, or unhappy. Go sharpen and have a beer, in that order.
The proof is in the proverbial pudding.
Nick! I am in the exact same boat as you with this sharping thing. A guy up the road from me is retiring and I bought a plane from him. I have a few older ones as well and now wanna learn how to sharpen them. I bought a diamond stone and now want an ultra fine ceramic stone for the final touch up. I’ve watched a bunch of videos about sharpening. I really like Rob Cosman’s channel. I’m excited with this new development in my woodworking journey!
BTW those planes are awesome! I wish that I had inherited some great tools like that. Your block plane looks really interesting.
I've watched a good handful of videos at this point, too -- there is so much out there it can be a bit overwhelming. I think I just have to attempt it and see what happens.
I've watched a few of Rob Cosman's videos but I'll have to revisit his channel.
Super jealous of your recent acquisitions.
And thanks, I am excited to have some inherited tools. Even if I just get the one solid Stanley #4 out of it I will be super happy.
Thanks for this Jake! It's super helpful to see. I ended up getting a cheap Rockler kit to start. A glass plate and adhesive backed sandpaper, plus sharpening jig. It was inexpensive but I want to give that a shot and see how it goes before investing in any stones.
Your handmade planes are very interesting. Do they work well? I remember seeing a plywood jointer (or at least fairly long) plane on Paoson's Woodworking YouTube channel and it seemed to work well.
I like yours better than the aluminum. Now you can make them and charge half price.
Bret
Cool! Nice use of the scraps, and a great use of the drill press.
You mentioned centering issues. Did you drill with the 1/2" bit right from the beginning? Consider starting with an 1/8" bit next time to drill pilot holes and jump up from there.
Super cool Nick!
[mention]nicholam77 [/mention] and other followers of this thread. I’ve been mulling over outfeed and assembly table ideas and came across this video on YouTube that captures most of what I think should work, and many of the folks I’ve drawn inspiration from.
Nick,
Wishing you and your family a very Merry Christmas and a happy new year!!! Enjoy celebrating with your little girl, it's truly a wonderful time!
Hi Nick,
Happy holidays to you and your family.
Great early present of the planes. Sharp block plane will get way more use than you would think, mine certainly does, even if it’s just sharpening my pencil.
Brad point drill bits FTW.
Enjoy your down time, take care
Best wishes
Steve![]()
