Chris702
I live in Washington State and have a home that's almost 3 years old with an attached unfinished garage. The wall that is attached to the house has drywall on it and so does the ceiling but the remaining 3 walls are unfinished. On the exterior its T1-11 so there is a visible vapor barrier on the interior on the back side of the studs. Last night I noticed that this white vapor barrier has turned a shade of green for about the bottom 3 feet on every wall. There are no leaks in the garage but since this is Washington we do park a wet car in the garage. I talked to the builder and he said no obvious leaks since it is happening on all walls and the garage is pretty air tight when the door is sealed up so parking a wet car in the garage can lead to moisture build up which can lead to mold growth. How can I remedy this? If I drywall the walls will this help? I am a bit lost, it is Washington State so its wet. I cant be the only one with this issue. Just makes it worse because its a new home and the builder is basically telling me don't park a wet car in the garage and it wont happen!! And advice??
