Hello, I just recently found this forum and have been looking through all the compressor rebuild threads. A couple days ago, I acquired a 1976 Champion vr5-8 80 gal compressor. The compressor is three phase, so I am planning on getting a new single phase motor and contactor for it. Upon removing the belt guard, I found the back of the compressor along with the intercooler coated in grease. I am assuming that the rear seal has a pretty good leak. Is there an acceptable amount of leakage from these compressors? I'd like to replace the seal; the oil sightglass is pretty dirty as well. Is it worth rebuilding the rest of the compressor while it's dismantled(rings and valves)? It seems like it has pretty good compression, just from moving the flywheel by hand.
Also, if I do rebuild it, how are the aftermarket kits as far as quality? I see I can get pretty cheap kits from ebay and compressorparts store.
Thank you!
Thank you!
