Weldomatik Aluminum Brazing Rods
californiamilleghia
SoCal
are those the ones demoed at every auto swap meet , its a zinc alloy that melts with a propane torch ?
Muggy weld or something like that.....
I believe you can get them at a regular welding supply shop if you know the number
(which I forgot )
C
Chilliwack Murray
Chilliwack BC
The video shows them using a propane torch and the puddle sticking only where they want it. Guessing there is some carefully applied flux they aren’t showing in the video.
MoonRise
Aluminum brazing rods. Different names/brands available, probably all the 'same' rods.
They can work.
Like most (all?) brazing (and soldering, and welding :lol: ), you have to have a little practice with the heat source (torch) to get things hot enough and evenly heated enough to get good results.
C
Chilliwack Murray
Chilliwack BC
Wait that’s not all, order in the next 10 minutes and we’ll throw in a harbour freight jack stand welder. (worker not the machine) Just pay additional handling.
gorilla
I just repaired some pot metal trim for one of my project cars with a Muggy weld product. It worked really well. It's expensive but there's not a lot of choice for this type of work. In the past a company called Eutictec (sp) plagued maintenance shops selling all manner of coated low temp brazing rods they worked but were stupid expensive.
kbs2244
I used for re-attaching a nut to a pier upright
it worked but the joint could not take the stress and failed
so, I would say it is OK for non-structural stuff
pi_guy
N/A
My welding teacher turned friend worked there had all sorts of samples.
It seems to work better if you have a tig machine involved.
bwringer
Indianapolis
The Project Farm dude tested a bunch of these.
I have no memory of the winner(s), so I'll leave that up to you. This guy's voice gives me a headache, but his videos are informative and his methods are generally pretty solid.
