Harley Branded Tools???
jeepnut24
Morrison CO
Can someone give me some more info on these? I think they are williams? But what is their COO? Id like to get the ratchet set for my brother, a harley nut.
mrshaun
Killeen - Fort Hood
they are bahco. I saw one of the harley dealer memos a while back and the paper mentioned bahco, a snap on company.
also for warranty it had some distribution company that i have never heard of.
J
jeepnut24
Morrison CO
Thanks
Does Snap On make any Harley specific tools, or sets targeted at Harley work?
mrshaun
Killeen - Fort Hood
yeah we are starting to make a bunch of stuff...
fuel tank tool
neck bearing adjustment tool
sam12le for the 12mm in the front fork tube
J
jeepnut24
Morrison CO
fuel tank tool
Thanks, he is getting his PHD this month, and I wanted to get him a starter set of tools for his harley as a grad present.
2dieseljohn
COOSBAY, OR
I have a 3/8 wench I got at the pawn shop a few yrs. back for a Buck that I believe is a Snap-on with a Harley name has a #of HDX12 and has a date date stamp that looks like S.O.'s 2001. Do these come with a HD? I've always wondered. Check E-Bay etc.. but I'm pretty sure SO did make some. Sorry about the 1st pic. I'll post a better one.
Kurn
Ravenna, Oh
These are not to be used as "tools". They are to be displayed in your Harley Davidson toolbox in your Harley Davidson themed den with you admiring them sipping a Harley Davidson beer in your Harley Davidson robe.
porschedude996TT
Santa Maria, California
I know you are just pokin' fun at HD's and I don't mind, but did you know that HD's in the early days were designed to drip oil. It was the way they did it back then. They had a lose lube system that oiled the primary chain from the engine to the transmission. It was pressure fed from the main pump and there was a weep hole in the aft bottom side of the primary cover where the oil was suppose to come out. Since the Evo and the Twin-Cam there is no losed lube system and mine doesn't leak or even weep a bit of oil.
Kurn
Ravenna, Oh
On Duo Glides and early Electra Glides they had a full(top&bottom) rear chain guard option because of the mess the chain oiler made.
compman25
Spokane
So they are Snap On! :)
warmpancakes
4th letter of the alphabet
brother has a 52 pan head we refer to it as "marking its territory":spit:
vssjim
McLean Va.
If you look at old big twin Harley's the ones the had a drip oiler for the primary chain and dropped out to the ground had sheet metal covers. Any big twin Harley the has Aluminum primary covers did not have oil drain holes in the covers the dry sump oil system had a pick up line at the bottom of the cover. Alot of companies make special tools for Harley's but Kent Moore makes the special tools that are in the workshop manual by part numbers. I thought the Harley branded tools s-o sold were first made and handled by Williams division then they moved them over to Bahco division for support.
crewchief888
NW indiana
mine stopped markin' it territory :dunno:
probably out of oil by now :lol_hitti
i dunno but mines actually been pretty leakproof over the last 30 years.
my only (very small) leak is from a stripped trans drain plug thats been leaking ever since i got the bike in '87
:beer:
Toolhorder
Montana
SOOOOO sick of ebay searches for Snap on ending with a million listings for Harley Davidson branded tools and every one says "Made by Snap-On" Mother Fer's!
Tool Pants
San Jose CA
I got this wrench at a flea market last year. Made by Williams with a Snap-On date code.
In my younger days I had a BSA motorcycle and a few English sports cars. I would worry if I did not see oil on the ground, because that meant it ran out of oil.
mrshaun
Killeen - Fort Hood
well search like this
new snap on -harley -belt -leather -faceplate -hair -cover -pink
do that and eliminate everything you do not want by putting a -???? then it knocks that out
click on this link then eliminate anything you want to from there
http://shop.ebay.com/i.html?_nkw=sn...pod&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
