I think they also reduce underbody drag. It's an effort to help improve fuel economy. I agree being able to remove a small portion of access cover would be ideal. They hosed that idea on my fusion. The oil plug is on the side of the pan. This causes it to drain with a nice long projected stream front to back. I was going to make a smaller access panel until I noticed this. I would need to add a feature or part to make it drain straight down. The oil filter location also isn't located in position that would make access holes a good option. Looks like I'll be removing the cover for several years. That is unless I get lucky and win the lotto. A new family car sure would be fancy!
Last night I was looking at the mysterious wiring issue on my wheelhorse 520-H. Tonight I'm off to poke it some more. I might be on to something or it's just tricking me again. Here a poke, there a poke, everywhere a poke poke..... Seems to be my general ability to diagnosis tricky wiring faults. Look out sparks.... Cheers,
Had a brain fart is what I did today.
Walk back over to bench & pull out a small ziplock bag for the Nylocs. Take care of that, put Allen wrench & GW wrench in the black plastic tray for "tools that need to be put away when I get around to it later"
Go back to bench & what do I find sitting RIGHT ******** THERE in plain sight next to the hardware cabinet??
The original bag of Nylocs AND the bag of 10mm Stainless washers...
FFS... Getting old *****.
On the upside, I had a perfect poop this afternoon so I have that going for me...
Dang, two fingers?
Sent from my iPad using The Garage Journal mobile app
I'm guessing you cut them on the ****** plastic they seal them in these days?
Swap the drain plug for a drain valve (Fumoto or EZ). Get the hose connector for it. A short piece of clear vinyl tubing will then drain it exactly where you want it drained.
If I remember correctly, acetone or nail polish remover will get the liquid skin off.The second cut on my pointer finger was from trying to remove the goo from the knife blades. I gave up after that....
I tried to put a 5/8" wood spade bit through my hand...a trip to the ER and 4 stitches later I am back at.
keep trying, no one likes a quitter.![]()
Hung this picture on my tool box today
Helped my son wash this big fella... It was 50 degrees in NE MO today so we took advantage of the great temps...
Asked if I could have them and they brought them over. Gave them a $10.00 as a thanks. Will cut them up and install them in my attic across the joists. Need a little yearly storage for Christmas items.Attics in Florida don't treat Christmas decorations well. I've seen things melt that I never knew could melt..lol And if it doesn't melt, it gets brittle and falls apart.Put a couple (FREE) sheets of brand new 1/2” plywood in the garage. 5 houses being built across the street and 4 next door to me. No I didn’t take them, guys cut a touch off each sheet and were tossing them in the roll off container.Asked if I could have them and they brought them over. Gave them a $10.00 as a thanks. Will cut them up and install them in my attic across the joists. Need a little yearly storage for Christmas items.
