scattermaster
SO,
new shop. new concrete floor.
I bought a rear flush toilet that will go out through the wall. When i was doing the trial fit, I found out that the bottom is not exactly flat. It rocks a little bit.
I was concerned about putting the ceramic toilet directly on the concrete.
Looking for opinions.
The hole is already cut in the wall so I don't want to put anything that will raise it very much. Most of the vinyl flooring I see is like a quarter inch thick.
That won't do.
Roll vinyl (linoleum) is only sold on 12 ft wide rolls. My room will be about 5ft. x 7 or 8ft. I thought I wanted to avoid having a seam but that means a pretty expensive piece that I have to buy.
I found the stick on squares of vinyl but the instructions say not to use on concrete??
Would I be OK with just putting the toilet on the concrete with some silicone or similar ?
That won't do.
