bmwrd0
Yeah, it makes a good paperweight.
I finally found the 1/4” MV-71. Now I have the set.
Interesting how the remover works. The stud would be done for but that would get it loose.
One big advantage of that design is that it works in tight quarters. Tight quarters are common on older aircraft engines!
If you heat the aluminum parts holding the studs, it makes removing them easier. Just don't overdo the heat.
Snap-On also made a collet-type stud remover/installer that gripped the exposed threads on the stud. I have one, including a few NF collets.
Just picked these up an estate sale-very very reasonably priced. Hoping they both work. Well it dawned on me that I am missing a piece or two from the compression checker. I can turn it into tire gauge I think but does anyone have a clue as to what goes on the end? I am assuming it was in a kit that worked on multiple engine spark plug hole sizes.
Thanks,
Mike
Bf768 is a auto body spoon
They are the CG500 series. Mine has a CG500-2 housing and I have the -4, -6, and -8 collets. I bought them for use on aircraft engines.
You can see them on page 251 of catalog #100.
I also noticed that curved iron on top of flat iron approach in the drawing, Mike. Cool to hear you tried it out.
My Midget set
