Kscardsfan
Does anyone have any advice on what to look for when buying one of these? I’ve been thinking about getting one for a while now, but just want to make an informed decision.
I would buy a quality 3 phase used grinder and add a VFD ( variable frequency drive) and you will have variable speed. What are you trying to grind?
Tool_scorunge made a good suggestion. Look for an industrial grinder that uses 3 phase, preferably 230V and then add a VFD to it.
Finding a belt driven belt grinder and converting it to variable speed might easier to do in your area.
Here's a link to a multitool grinder, same one I just ordered.https://www.trick-tools.com/Multito...er_Attachment_8_inch_Contact_Wheel_MT8CW_1164
What is the benefit of a variable speed grinder? In my experience abrasives need a fairly high surface speed to be effective and cutting rate and surface temperature are best controlled with pressure and/or coolant. What am I missing?
OP. I apologize for the potential thread derail. I thought about starting a separate one but I thought the answer to this question might help you in your decision making process.
I would get a cheap HF belt sander and use aluminum oxide belt for metal. Belt sanders are way better and faster. I haven't used my bench grinder in 20 yrs to grind metal except to use a wire wheel.
