Help with My Atlas Drill Press
Newsmitty
Pa
Just picked up an Atlas drill press and I want to do some well deserved maintenance to it. I don’t think it has ever been cleaned and I guy I got it off of didn’t seem to have cleaned it ever. Pulleys and belts are in good order and I found some literature on it. It is a model 54 serial number 000771, however the images in the literature look a little different. I have an extra pulley attached to the top of mine (which I have seen images of Craftsman DP that look like that). I guess I am looking for any guidance with the maintenance and ideas I where I can get new bearings (if mine are going-after I tear it down). Thanks for the guidance and yes I am a newbie to this.
bob15
Northeasten, CT
I would just clean it and add a little 3 in 1 oil (or any fine lubricating oil) to the wear and moving parts. I wouldn't change bearings unless they are really needed.
hefnerconstructionlc
Kansas
I agree as above. Just blow it off with some nice compressor clean it up give it a coat of oil. And then run the thing and see if it sounds fine. It's not out of balance and isn't making a squealing noise. then it's likely fine it's probably set more of its life than it's actually been used. If it's not squeaking either from a bearing or a belt. I would just use it that old stuff is made the last. If it's binding up and squealing then you can start looking in the bearings. Otherwise just use the thing.
climb.on
Minnesota
That machine looks to be in fine condition. Seriously. Great find. Nothing better than those old heavy cast iron machines. I would clean the grime in with Purple power or something of that sort. Put a little lube where it's needed. A razor blade works to scrape the rust on the table then a little oil and fine steel wool should take care of that light rust. If bearing, parts or other adjustments are needed, you could always hear over to owwm.org for some great advice.
N
Newsmitty
Pa
Would any of you take the chuck off to clean it or just take some q-tips and use them to clean the inside of it?
Davefr
OR
I always service bearings in old machines. You can usually get by with cleaning them thoroughly and repacking them with fresh grease vs. replacing them. I can almost guarantee that they are all dried up inside.
If the chuck opens and closes easily then just blow out the inside/jaws with compressed air.
Nice clean machine!!! It's nice to find them in that condition.
rlitman
Long Island
I always service bearings in old machines. You can usually get by with cleaning them thoroughly and repacking them with fresh grease vs. replacing them. I can almost guarantee that they are all dried up inside...
I have an old Atlas floor standing drill press from around that vintage. In it's second life (before I got it), it was used to make the tooling that made Atari joysticks (if that helps date it).
The quill bearings are sealed, and are still in perfect condition, never touched to this day. Yes, I too would normally recommend servicing bearings, but this is one tool where I'd suggest skipping that.
More importantly, pull the cap on the return spring and spray some oil in there. Those clock spring returns are known to snap when they get dry, and I've seen many of these Atlas DPs with broken springs.
justanengineer
Motor City
If you need bearings I would suggest google for finding bearing suppliers local to you. I use Kaman Industrial regularly for this, just take in the bearings, shields, and anything else you need and let them measure or cross reference the numbers. Usually the counter people are more than willing to answer any questions you have and give you options for speed limits, sealed vs shielded vs open, etc.
If the chuck is gummy there’s a million sites and videos online showing how to press/tap them apart for cleaning. It’s pretty simple and makes a world of difference in terms of smooth operation.
FrankLee
seMI, 48317
Standard Atlas drill presses did not come equipped with that extra pulley. It is a very desirable and sought-after optional accessory. Check ebay for sold prices.
This post may be helpful: https://www.garagejournal.com/forum/showthread.php?p=8673207
N
Newsmitty
Pa
Well I decided to take it apart to do a good cleaning. Will have more pictures and lots more questions. I am already finding possible issues (gaskets near the front spindle that looks like it was loose and bouncing around when the drill was on).
N
Newsmitty
Pa
Ok, I got the quill ok and it looks good but I found some type of rubber bushing that was on top of it that is not in the best of shape. Could not find it on the diagram for this model, anyone that can help with that would be greatly appreciated. Also found little adjustment screw (I think) when I removed the center pulley. Don’t think it came off the pulley so any ideas on that will help too. Everything else is looking but will just need a good cleaning. Motor was working but I might try to clean that as well. Thoughts?
FrankLee
seMI, 48317
That would be the quill bumper. It should be installed in the head frame casting, but obviously came loose. You could try to flip it over and reinstall, or I do have a spare in decent condition.
I have no ideas on the set screw.
N
Newsmitty
Pa
Do you have a picture of your spare so I can see how bad mine is torn up? If it is to bad, would you be willing to part with your extra bumper?
tool_scrounge
Southern California
Here is a link to a long sold Atlas center pulley of mine with ,its of photos if that helps. I do not remember a set screw In it
https://www.garagejournal.com/forum/showthread.php?t=295569
N
Newsmitty
Pa
I was asked so here are some measurements:
My bumper is approx 1 3/4” OD. My quill is about the same. Yes the lock sleeve handle was replaced with a wing nut. What does it lock in place? Column is 2 1/4” OD approx
N
Newsmitty
Pa
I think I found what the set screw went to-the collar on top of the quill. It was missing. Could also explain why the bumper is torn up. Is the bumper suppose to sit on the quill like in the below picture-just that all of that is inside the head when assembled? If that is the case I might just have to make a new one out of a piece of rubber unless anyone has any other ideas for material to use.
FrankLee
seMI, 48317
That is the correct location for a set screw, but that set screw is way too long and likely caused the shredding of the bumper. The set screw should be near flush with the OD of the spindle collar.
The bumper gets installed in the head casting and the top edge of the quill bumps up against it.
What is the diameter of your quill? There's probably a better option than that oe bumper.
N
Newsmitty
Pa
My quill is 1 1/2”. I was thinking of maybe doing a nylon bushing if I can find one that I can make fit in the little alcove in the head.
FrankLee
seMI, 48317
OK, 1-1/2 is what I thought.
Because you have that sleeve at the bottom 1" of the quill, you would probably be better off installing a quill bumper just above that sleeve. There should be plenty of standard 1-1/2" rubber plumbing fittings/gaskets/o-rings that should work well.
Below is a picture of a 2nd-gen Emerson Craftsman quill with bumper. This one is 1-5/8" diameter, but should give you an idea of what I'm talking about.
N
Newsmitty
Pa
Is the bumper in the head suppose to be a guide or is it just for when the quill is return back up, that it keeps it from hitting something else in the head?
FrankLee
seMI, 48317
just for when the quill is return back up.
Without the bumper, I believe that sleeve at the bottom of the quill would contact the casting. Easy to test. IMO, that rubber donut was a bad design.
scupoli
Can some please tell me where I can find the quill bumper, depth Stud screw, and a another handle with ball?
I've got an Atlas 73 drill press. I'm restoring it with a new paint job.
Thanks.
WhiteBimmer
Newbie to the forum and hope it is still active?!
Have an original 20+/- yo GLOBAL FLD-14 bench-mount drill press which has started to "chatter".
Not sure if it is the belt but given presses age, I bought one.
From googling on vintage presses, it appears that noise may be bearing that needs to be repacked or replaced.
Do not have a manual so hoping that a member of forum does or know where I might obtain one.
Any info re the FLD-14 would be greatly appreciated.
