I got a Kobalt 60 gallon 2 stage compressor a few weeks back. I finally got it all hooked up and ran the break in. Once that was done I ran it up to full pressure and I thought it seemed to take a very long time to get there. I didn't time it or anything, but it was quite a while. Anyway I needed to actually use it, so I did. I was running a needle scaler which should be ~5 to 6 SCFM at 90 psi. The compressor should shut off at 175, but I think it was 180. Regardless it should supply 7.6 SCFM at 90 psi, and after a few minutes running it would be down below 90 for sure. I think I got it as low at 60 psi even.
I am 99% sure it is wired correctly and the motor is spinning the correct direction. Nothing seems to be leaking that I know of. Not sure what else I can check. The only other thing I could think of would be to put an ammeter on it which I haven't yet. Basically I am not sure if something is wrong, or if I have too high of expectations for this compressor?
Thanks,
Sean
Thanks,
Sean
