Soldering iron
MeentSS02
Dayton, OH
Depends on what you are trying to do...I've been using an older version of one of these for years, and actually just got done using it today:
https://www.amazon.com/dp/B077JDGY1J/?tag=atomicindus08-20
Obviously that's a station, which you said you didn't want, but if you want good and dependable, that gets my vote.
If you are going to be soldering large gauge wire (like 12 gauge and heavier), you'll need something like this:
https://www.amazon.com/dp/B000TDGI18/?tag=atomicindus08-20
This might be close to what you are looking for:
https://www.amazon.com/dp/B000AS28TS/?tag=atomicindus08-20
Or this:
https://www.amazon.com/dp/B00FZPSX3G/?tag=atomicindus08-20
Weller and Hakko are two brands I trust. I'm sure you can find cheaper if you are willing to take a chance with a knock-off of some sort.
PassnThru
Bowling Green KY
Anyone know of a good soldering iron that they would recommend. I don’t want a “soldering iron station” but want a good one that is dependable!
Thanks!!
What are you going to use it for? Hate to say this since you are against soldering stations but they will give you the most flexibility. Soldering is not a one size fits all thing. The more you solder the more you learn what you didn't know about soldering.
K
Krfjkm
Charlotte / Mint Hill NC
Thanks!! I like to be able to get in different places for my soldering. Sometimes stuck under the dash of an old car— today I was soldering a wire for a new garage door opener I installed—- that’s the reason I am leaning more toward something that is portable.
K
Krfjkm
Or this:
Thanks for the suggestions!! I’ll check them out!
ddawg16
S. California
The 'advantage' of solder iron station....you have a place to put the iron.
I've used everything....a station is the only way to go. If anything, the on/off switch makes it worth it.
For bigger stuff? Get a torch....
rangerfredbob
Oregon
The Harbor Freight butane soldering iron isn't bad, I have one of those... once I get my shop up in running condition I plan on getting myself a soldering station, we have one of THESE at work and it is amazing...
Jlarson
Hakko or Weller, both make nice little hand irons.
I will drag out one of my Weller WESD51 stations and put a screwdriver tip on it if I'm doing a lot of splicing like in a cab in the shop, the pencil iron on the station is a lot handier and easier to use then you'd think.
eacmen
Maryland
I don’t really solder wires together anymore, its hard to get a good joint with the wire still on the car. Instead i use these and have not had a failure yet:
120PCS Solder Seal Wire... https://www.amazon.com/dp/B07S62KYSL/?tag=atomicindus08-20
All you need is a heat gun and you’re done.
Crazyjake8493
Upstate NY
Those are the way to go. Even just the crimp and heat shrink ones are good if you buy a name brand. Soldering is a good electrical connection but not a good mechanical connection, even with some heat shrink tubing. The connectors you listed are both.
I have a cheap soldering iron for benchtop work and a PowerProbe butane soldering iron for field work. Very few scenarios in automotive where I would be soldering, short of repairing a cold solder joint on a circuit board of some kind.
I used to work as a RV mechanic in a big shop and I can count on one hand the number of times anyone soldered anything. It was always good-quality crimp and heat shrink connectors.
eacmen
Maryland
Posi-Lock connectors are also amazing. For jobs where I may want to rewire later I always use Posi-Lock or Posi-Tap. Never had one come undone yet.
Smittybert
I have a Milwaukee m12 cordless and would never go back to a 110v. I works great has a light and heats up fast.
aggie113
San Antonio, TX
If you do change your mind on a station, I'd recommend an Aoyue 937(8). I've got an older version that has served me well for many years. The digital readout and fine control on temp make it worth it for my uses.
speed88
Illinois
I just picked up a hakko 888d. What’s and good general temp to set it to for soldering? Also what are some good tips for the iron to have on hand? Last time I have done any soldering was with a cheap $10 fixed temperature iron.
fsae0607
San Fernando Valley, CA
What are you soldering? I like screwdriver tips. I like to set my soldering station around 550°F or so. Get rosin flux, too. It'll really help your solder to flow to where you want it to go.
speed88
Illinois
Thanks man!
I ended up ordering a few different types of solder and a few tips to try out. I also pick up a cheap little soldering diy kit to practice on and hopefully improve my skills a bit.
These are the tips I ordered.
T18-D32 Chisel Tip
T18-S3 Chisel Tip
T18-D24 Chisel Tip
T18-D12 Chisel Tip
T18-D08 Chisel Tip
T18-C2 Bevel Tip
Bert_
NW Iowa
A bit late as the OP got a Weller station almost 10 months ago.
Just an FYI the wp35 is just an iron not a station.
Maybe we can get an update from the op and hear what he thinks of it? I've had a wp35 for 5 years or so and it's a great iron!
FredWanaker
NorCal
TOTALLY depends on how and when you will use it. One thing to solder loose wires and another to solder a circuit board. I keep an old Weller gun around for quick wire jobs - but be careful soldering in cars - sometimes that will only create future problems. That would be too heavy for a newer circuit board. But just for a quick job these have two settings - you can pull the trigger all the way to get the tip hot then back off to low. That said, pick your solders well - the wrong solder for the job is worse than the wrong gun. Also, I use a soldering pencil with different tips for circuit board stuff and a magnifying hood.
Weller two temp gun:
https://www.amazon.com/dp/B000JEGEC0/?tag=atomicindus08-20
Metal-Marc
Foothills of the Adirondacks
This.
