Of course! I have been lost without them....ImportTuner said:Acording to LTI, it's a must have product ...![]()
wilbilt said:The LT-680 "Lower Control Arm Tool" is pretty scary. Just to think I used to do them with just a pry bar. It looks like I didn't know what I was missing...:
kartracer55 said:Have one guy hang on the pry bar and another guy smack the lower control arm with a good sized hammer and you can pop them right out. Pretty slick.
wilbilt said:Easy to do by yourself, too. You can pop the taper before prying it down, or pry down with one hand on a pry bar and pop it with a hammer in the other.
I've done it thousands of times, practice makes perfect.
kartracer55 said:How would you pop the taper before prying down while still being able to use the ball joint? Im tryin to learn whatever I can so anything I can get is awesome
Jim
wilbilt said:Assuming a FWD vehicle with strut suspension (not going to explode and fling a coil spring at you)...just loosen/remove the ball joint nut with the weight off of it. Smack the knuckle with a brass hammer in the vicinity of the ball joint, and the shock should break the taper loose.
Pry the control arm down, and the BJ shank should come right out.
wilbilt said:Smack the knuckle with a brass hammer in the vicinity of the ball joint, and the shock should break the taper loose.
Leverage is your friend.The LT-680 "Lower Control Arm Tool" is pretty scary...
Damn straight.I believe TNT has his own creation like this...
