welding Alu stick on 110 -
CamaroMan
Hi all! as usual im trying to work with what I have - weld aluminum outside with stick rods on 110v.
There is an old school miller thunderbolt 225 available but its 225/230v - is there a 110v AC welder I can try push a 3/32 alu rod with?
metaleltr
Western Ohio
Harris recommends 50-85 amps for alloy 26(4043) in 3/32". Any dual voltage stick welder should do what you need. ESAB miniarc comes to mind. Everlast powerarc is also an option.
dwcon1431
Sorry I don't have a solution but, your post caught my eye because back in the '70s, I worked at my first job in a metal shop where we did welding. At that time, I was 18 or 19 and naive. The welders would send me to where the rods were stocked and ask me to look and find some aluminum rods which didn't exist at that time. Good times were had by all.
Sent from my SM-A102U using Tapatalk
The 52 Ford
Virginia
Honestly, any DC stick machine of reasonable quality should do just fine. For a 3/32 Messer MG-400 (only Alu rods I have), they say 50 to 80 Amps on the box. If I were you, I'd try Harbor Freight. Their newer "Titanium" and "Vulcan" welders look like a pretty good deal. Tractor Supply has a 110V Forney welder for under $250 and it has good reviews online. The other route you can go is "low temp" aluminum rods. You can use a MAPP torch and basically braze with them. I've been meaning to buy some and try them out. For something like a leaky John boat, it would be nice to just carry a torch and rods to the boat, instead of having to use a welder.
Sent from my SAMSUNG-SM-G891A using Tapatalk
The 52 Ford
Virginia
Like sending a kid at a garage looking for the blinker fluid or ask them to grab you a left handed screwdriver.
