Bench top power supply
v1ru5879
Would like to start adding some accessories to the truck now that it's warming up. Before doing any final installs the idea of having a bench power supply to test with strikes my interest. Should I go the diy route or get a small one off Amazon? Don't wanna spend over $100 for what I'm gonna use
Sent from my Pixel 3a XL using Tapatalk
flyt100
Minnesota
A desktop PC power supply can be handy and good bang for the buck if you don't need adjustable (and you may have one laying around in an old computer)...
V
v1ru5879
Mainly cameras off-road lights and head units
Sevenhills1952
Virginia
This Weltron is 50 years old, I made the "guts" years ago, it's 1.5v to 25vdc @ 2A max. I got one like this China one but 10 A, 0-30V. I'll use them occasionally.20210307_193348.jpg2021_03_07_19.29.17.jpg
Sent from my SM-S205DL using Tapatalk
V
v1ru5879
That's the one I've been looking at on Amazon, I can't think I would need much more than that
Shiftless
East Bay SFO
I used to use my 10 amp battery charger but now I use this.
Dancing Bear
Clearwater, FL
you can also buy a desktop PC power supply and use it as a benchtop unit ... they turn 120V AC into 12V, 5V and 3.3V DC on the different rails .... some of them can deliver 20+ Amps on the 12V rails. Thats what I use for benchtop testing
ttpete
Dearborn, MI
I fished mine out of a dumpster. It's a Lectroetch etching power supply. It's capable of 0-30 volts DC or AC and up to 50 amps. It uses a Variac to adjust the voltage and has both a voltmeter and an ammeter. I had to install banana jacks on the front panel to replace an original connector.
Shiftless
East Bay SFO
ttpete: Dumpster find? you ****!
The newer and wimpier model from that company only delivers 10 amps and DC only. It retails for $300
ttpete
Dearborn, MI
It's been on the shelf over the bench next to the Simpson 260 and the shop Fluke for 20 years now. I found it the week before I retired, out back by the loading dock.
dogdog
If it was me...I like to build one...
but if I am looking at cost... I would have just gotten the build one ...
either case, plenty of selections.... Just have to define what exactly you needed first... 10AMP 20AMP 6AMP etc...
You can build one off a programmable CC/CV controller but you would still needed to get the power supply
V
v1ru5879
I think something 20 amp max would be sufficient for most vehicle accessories. I may go with that one linked above from Amazon.
theoldwizard1
SE MI
Cheapest is a battery and whatever battery charger you already own.
Next step up, is a used computer power supply. You need to short to pins together to get them to turn on.
You can get a 0-30V, 0-5A (or 0-10A) supply on Amazon for about $60 ($80 for the 10A).
Super deluxe, go to eBay and look for Riden power supplies or AlliExpress. These are either the front panel and electronics only or a kit (quick easy assembly). Many positive reviews online.
DIY_Guy79
Tulsa, Ok
If you're going with a chinese option, Banggood is your best bet. They have a lot of different options within your price range. The Riden line they have is very popular. However pay close attention to what you're buying as many of these are components to build your own. As in the main interface where you need to supply your own transformer or power supply or something of that nature. If the DIY option is attractive to you, then they have tons of components here and there are tons of builds on youtube that you should check out. Biggest issue I have with Banggood is the shipping from China is... lengthy to say the least. But they do have some USA warehouses they ship from, you can check to see if that option is available on each item you view.
Here is a unit on Banggood, 30v 10A: https://www.banggood.com/TOPSHAK-K3....html?cur_warehouse=USA&ID=47757&rmmds=search
But that one doesnt seem to have fine/course tuning.
For $49.99. It is available from a US warehouse. And make sure you check for coupons, they have a huge coupon section to look through. If you're new to banggood you get some pretty decent coupons for being a new customer.
Also, just fyi, on Banggood you have to actually read the reviews. The star rating is useless as I dont believe there is a way to change the star rating, so every review is 5 star, whether good or bad lol.
theoldwizard1
SE MI
dogdog
Isn't that true of most of the **** out of China?
Ignorance Is Not a Bliss
It all dependents on what you are doing and what you are looking for. Most people have no idea what they are doing even with power supplies, analog or smps. .. or know what are the requirements of a good power supply... let alone design one better than the craps out of China or knows how to differentiate **** from the #2 that spew out of the brain. Just saying. there are a lot of craps out of China... not every one of them are design by Chinese. They just made them to spec or price and target market..Maybe you are attracted to their **** market. We have this discussion before and almost every month.
