Budget Rotating Hammer
zendriver
Indiana
Rotary Hammer
Just needed for concrete/masonry projects around the house, so I don't need a $500 model.
Sub $200 range
Also, any sources for good priced/quality of SDS bits?
Looking to remove cement mortar and chip off old mortar, off concrete. drilling holes in concrete, etc.
loganb
Omaha, NE
Top of the line...a used Hilti if you want a corded version but one in decent shape at your price may be harder to find
Next up but still highly capable for what you're wanting for me would be a Bosch Bulldog corded unit...either this or the Hilti should be pretty common on the used market
If cordless is desired I'd get the real rotary model for whatever 18v platform you have. I opted for this route and have been very happy with the Makita, makes punching holes for wedge anchors or even just Tapcon or GRK anchors a breeze and much more enjoyable than the hammer mode on the cordless drill
Sent from The Garage Journal mobile app
Todd.Brock
Cincinnati
Not sure I’d have this if I needed to make a living with it, but it’s done everything I’ve asked.
I also have a 1/2” chuck milwaukee corded hammer drill from CPO outlet for like 75 bucks. It too has never failed. Just depends upon your needs
Zewnten
Second the HF option, used the Chicago Electric version for years in previous work drilling holes for repair. Your not using it daily so I'd go used, possibly risky, or HF and if you're worried about it get the warranty and swap it every year
tarbellb
Oregon
Anything from Hilti or Bosch in good condition is a good buy typically.
But honestly, your requirements are checking all the boxes for.... Harbor Freight
HF has lots of good reviews and its waiting on a shelf w/ a warranty.
dscheidt
I've seen a fair amount of HF rotary hammers on job sites. I asked an electrician about it. "They don't walk off" was a big part of the answer.
alinc100
Dearborn,MI
I have had both Hilti and HF , both function as they should. The HF was an earlier Chicago Brand that had a tendency to slip out of gear. I used it as a demolition machine for a couple tiled bathroom jobs.The Hilti was a roto hammer only, no chipping only function, so I sold both on FB Market place after buying a Bosch at Lowes .With the current promotion they give you the battery and charger. I've only used it on tapcons in brick mortar so far but the cordless feature was helpful as we were in and out of a sky lift all day. I wasn't thrilled with adding another brand of battery tools as I have Makita and Dewalt ,but 3 isn't much more than 2 and due to a tool in the street find I had a 2nd Bosch 18v CORE 4.0 battery that didn't have a charger,tool or twin battery until I paired it with the Bosch. Bosch makes good SDS bits as well.
At $149: https://www.lowes.com/pd/Bosch-CORE18V-3-4-in-SDS-Plus-Cordless-Rotary-Hammer-Tool-Only/1000279331
At $199:https://www.lowes.com/pd/Bosch-18-Volt-SDS-Plus-Cordless-Rotary-Hammer-Tool-Only/1000979918
jg4660
Western NY
Another vote for the Bosch Bulldog..easily found new for around $159. I even used mine to drive 8' ground rods...works great.
timgunn1962
Lancashire, England
It helps a LOT to sit down and decide what you intend to do with it. There is a huge difference between a big one and a little one.
Here in the UK, most houses are built from brick. Brick varies hugely with location and local geology. Around me, the geology means that most brick is made from shale and is ****** hard (the Empire State Building was built on "Accrington Nori" brick foundations, shipped over from England, because it was one of the few bricks hard enough to take the weight of the structure without crushing. Accrington is about 8 miles from me). Drilling brick walls with an overly powerful SDS tends to knock the back out of the bricks. The same thing applies to concrete block walls, though to a lesser extent.
Here, I'd recommend the cheapest 2 kg-class (circa 2J impact energy) SDS you can find as an ideal DIY drill. If you are already into an 18V battery system, an SDS from the appropriate range would also be a good option. Expect to be able to drill up to 1/2" holes in brick/concrete/masonry with no problem at all. Up to 3/4" will be doable, but will be noticeably slower. Occasional holes up to 1" will be achievable, but not something you'll want to do often, in my experience.
Clearly the construction methods in your location will affect the tool most appropriate for your use. If you anticipate needing more grunt, by all means get a bigger machine (3-4 kg and >3J impact energy), but expect it to be quite destructive if used for more delicate tasks.
I have used a range of SDS drill bits at different prices. I do tend to buy from drill suppliers, so have probably been spared dealing with the really cheap ones that just don't work. My experience is that the "good" ones last maybe twice as long but cost 3 times as much. Sharp is a bit of a misnomer with SDS drill bits, but "sharper" ones drill much faster than blunter ones. Cheap carbide doesn't seem to wear much faster than expensive Carbide. Buying cheap and changing often will get more work done in any given amount of time than buying expensive and trying to eke out maximum use from an expensive drill bit, in my experience.
WagonHo!
Albuquerque, New Mexico
I have 12’ sections of 3’ high coyote fence atop 4’ block wall anchored to the pilasters by angle iron. Once side pulled out as the installers used a 1 1/2” security screw into a crack in the block?? Anywho I had picked a used electric Milwaukee rotary hammer drill on Craigslist for $80.00? Whoa nelly that thing was a pleasure to use 5 minutes all 4 holes were drilled thru block and concrete. Don’t mind running an extension cord if it works that well. I had first tried my 18v Makita drill driver and it was futile. This guy that sold it wanted to go all cordless and it worked out great for me.
Sumboodie
AK
I have one similar. Has worked fine for my needs.
dogdog
Rotary Hammer
Sub $200 range
Bosche ones is really nice if you wanted new...
SDS or SDS max ? For sds Max Dewalt bits are really good, Hitach bits are really good, no name brand and HF bits are questionable. Those are the ones I have and used.
Sumboodie
AK
Maybe some time back. They are about $200 now. Can get a reman'd one for around $160, though after the shipping, may as well just buy brand new.
Voi
Western South Dakota
Acme Tools had one of the corded Bosch rotaries for sale for $179 with a promo code earlier this week.
I don't recall which model it was.
If you can't find it let me know & I'll see if I can find it.
logical
Northern fringe of the Motor City Suburbs
Shoot me a note if you might want to buy mine. Bought it new/unused on Craigs to do my lift install so it's drilled 16 holes total. Milwaukee with old school metal case. I have a 3/4 x 13" bit only. 1 & 1/2 inch max stop rotation rotary hammer, up to 6" core bit. Bits are different than most and not in most stores but available on ebay and Amazon.3615435f64eff04ad9e1b51c16d6255e.jpg
Sent from my SM-G960U using Tapatalk
brianh
grahamsville NY
I bought a 75 dollar HF Chicago electric SDS to drill my slab for the frame mounting studs in 2010 it has been used on other jobs and still works fine.
Coach James
Sandhills of North Carolina
I have a SDS plus and a SDS max, both HF Chicago Electric. Drilled holes up to 1.5 inch diameter through 4 inch concrete many times with the MAX one. More 1" diameter holes than I can remember with the Plus one.
Zero problems from either.
Coach
IndyGarage
Indy
I had a Hilti TE-7 and it worked great - bought it used from the Home Depot rental department for about $200 - sold it a few years ago for $170. It couldn't have had more than a couple hours use when I bought it. I used it for a few projects and it worked great, but it was a rarely used tool.
I eventually bought a Panasonic cordless - didn't need both, so I sold off the Hilti.
I always look at what Home Depot has for sale from their rental department - bought several nice tools that way.
Dodge
Illinois
I have a HF rotary hammer drill. I have had it a long time, no issues. I would buy another one if I had to. Now the Bauer brand is supposedly even better. Don't be afraid of the HF!!
Jland
Colorado
Got my bauer sds rotary hammer for 79 bucks. Bought a sds adapter and 1/2" chuck for less than 20 bucks... It beats the **** out of everything I try to break up. My only gripe is if I run a ship auger.. you have to drill all the way thru. No reverse. From mixing thinset to busting rocks.. no complaints
driftpin
Chicago Electric 8-1/2 amp 120V SDS-MAX demo hammer/drill, cost me $90 a few years ago. Did several demo's with it of bathrooms, saving us $2K from the budget the GC had for that, because I did it. I bought the HFT demo bit set SDS-MAX, and they did the job, as-did the HFT carbide concrete drill set, the pins were >1/2", I forget the exact size w/o going to the garage to see the box.
Demo'ed a 14' X 16' stucco shed, 8,000 lbs on the county dump weight tickets.
Anchored a 10' X 20' premanufactured building of steel-frame Hardie-Board siding on 3/4" plywood, to a concrete slab, after the scheduled installer couldn't get his DeWalt cordless impact drill to make even one hole of the proper depth.
I made sure to fill the gear vault with fresh grease every day.
