Help With Coleman Powermate Generator
D45
NW INDIANA
I picked up a VERY gently used Coleman PowerMate MAXA ER 5000W generator today, for $60
5 gallon poly gas tank, Tecumseh 10HP cast iron sleeve motor, low oil sensor.
It has four 110v outlets and one 220v twist lock outlet. Its a nice machine with good features.
Changed the oil, air filter, fuel filter, and spark plug
The only issue...........it is not making voltage
I took the brushes out and they are over 5/8" long with a ton of material remaining, and seem to be in great shape. So I don't think the brushes need replacing
Inside the mounting area for the brushes is a round cylinder, which I believe to be some sort of capacitor? Could this be the faulty?
Its a Teapo capacitor and costs $20ish on Amazon or $12ish on Ebay
#0034819.01
Anything else I can do or check to find a solution for the machine not generating power?
kelpaso1
MEMBER EMERITUS
New Brunswick
Look up "Re-flashing a generator". Usually needs to be done if they sit for too long unused. Can be done with a corded drill. EDIT: be quick to release your hand from the chuck when it starts up :bounce:
Justin James
kelpaso is correct. The capacitor may be bad, but if the unit sat for any length of time we always start with a "field flash" of the alternator. What you will be doing is sending 12v through the brushes directly to the rotor. Is is polarity sensitive so you must determine what brush is P and which is N.
Lightning rod
Toronto , Ontario
if you have time, this guy does a great job at diagnosing and repairing generators
reflashing with a drill has never worked well for me
I prefer to use a 12v battery across the brushes to start the reflash
both methods covered on the YT channel - just have to find them
D
D45
NW INDIANA
The generator was used in the fall of 2020 and stopped producing voltage
I am going to try installing a new Teapo capacitor first
Jking24
#0034819.01
I'm not a generator tech by any means but it's not likely the capacitor. They usually lose the rectifier/ voltage regulator box. If you Google it their are plenty of videos that walk you through how to check voltages. If I remember correctly most generators have a low voltage side that charges the feild for the high voltage side so you need to figure out what your missing first as far as inputs and outputs
D
D45
NW INDIANA
I looked at the parts schematics and don't see a voltage regulator or rectifier
Lightning rod
Toronto , Ontario
Rectifier might be on the brush assembly as 4 black cylindrical parts (diodes)
If not on the brush assembly , there still has to be a rectifier to feed DC to the rotor brush’s
Not all gen sets have regulators
I have not been able to find an electrical schematic for your model
Only a parts breakdown
If you have the electrical schematic, can you post it?
theoldwizard1
SE MI
Re-flash first !
You can power the brushes directly from a car battery after disconnecting the other wires. If you still get no output you likely have a bad rotor or stator.
Lightning rod
Toronto , Ontario
also , I will mention , that if a capacitor is present, the design of this generator may NOT
have brushes or rectifiers if it is a brushless rotor design
thats why it is important to identify what design you have
if you have a brushless rotor design, then the capacitor will affect the output voltage 100%
reflashing the capacitor is done differently In this case
D
D45
NW INDIANA
I hope the attached files work
D
D45
NW INDIANA
Well the new capacitor was installed and did not fix the issue
Looks like I will try the "flash" technique
Will a small lawn/garden battery from my riding mower work?
larry_g
oregon
Model: PM0525312.17
Capacitor P/N: 0034819.01
Stator 5.0Km 60Hz P/N: S0055635
Diode Assembly P/N: 0006006
I dont see this part anywhere on mine
https://www.manualslib.com/manual/134032/Powermate-Maxa-Er-Pm0525302-17.html?page=6#manual
https://www.searspartsdirect.com/model/3093e6figb-000214/coleman-pm052531217-generator-parts
In your third picture above the diodes are at the end of the bar at the bottom of the housing and have a yellow wire connected to them.
I just went through a generator problem and documented it here, https://www.garagejournal.com/forum/showthread.php?t=477507 Mine is a bit different but the manuals linked to have some theory of operation and troubleshooting in them that may help you. https://redirect.viglink.com/?forma...www.manualslib.com/manual/76...page=23#manual
lg
no neat sig line
Boilerhouse
Muskoka
I have a 3500W Coleman Powermate Generator and have had to reflash it a few times, although not for the last several years since i am now smarter about properly shutting it down. Anyways, the manual says to use a 6 volt battery to reflash, and that is what I have always used.
D
D45
NW INDIANA
I did find the diodes, I was thinking small diodes like from a circuit board
I took both off and cleaned the contacts on the diode tabs and also on the wiring connectors.........a little surface rust
I also found a broken wire inside the generator........supposed to have two wires soldered on to the disk. One was broken. I soldered the two together and still no power.
I then found an old cord from a vacuum and plugged it into the generator. Powered up the motor and used the other end of the vacuum cord on my 12v riding mower battery.
BINGO!!! I now have power in all the outlets and it seems to be functioning as it should
When in doubt, flash it first!!!
I never heard of such a thing before
