I'm currently having a horizontal 1980s Campbell Hausfeld 30 gallon tank pressure tested by a local fire extinguisher outfit. Tag says certified in 1980, working pressure specified as 165 psi, shell thickness is ~0.114 per my memory.
I've been able to look inside and saw a lot of large scale(?) chunks and general rust, and perhaps oil. Unsure. I washed the inside with simple green, then let it sit over night with evapo-rust which had some positive effect... hard to know how much scale is still stuck to the bottom.
The tech doing the test is going to test to double the stated working pressure on the tank for 30 seconds. He said if the tank yields at all during that time the pressure will drop and it'll fail the test.
The main question is: if this tank passes the test, should I use it? I'm unfortunately very limited space wise, and only have enough room for a 30 gallon. The compressor will likely live under the work bench, which means if it failed catastrophically it might take me out in the process.
There's always the possibility of paying a few hundred for a newer compressor and cannibalizing the tank (I would mount my SB703 with a 3hp motor), but money is tight and I only paid 40 dollars for the Hausfeld.
Any and all advice would be much appreciated. Thanks!
