cls89
I plan on installing fiber cement siding on the outside of my garage. The panels will be installed vertically. Going over the old siding. See link for product details.
I want the end result to look nice so I’m looking for advice on best approach to cut the opening for the electrical conduit. See photo. Should I measure and drill a big enough hole than cut the panel across it’s length, cutting the hole in half than I can join the panel around the conduit like a puzzle? Should I cut the panel across it’s length first and than cut some semi circles on each side so I can fit around the conduit? In ether case I would think I need to hide the opening around the conduit with some type of flange/ round trim cover. Any recommendations for flange covers? It would need to be two semi circles that clip together. Unless there’s something else I can use.
Also I want to hide the seems between panels. Is there a joint cover/H-Molding I can use to hide the seams between the siding panels?
https://www.menards.com/main/buildi.../primed516x4x10textpan8ng/p-1444450998347.htm
