applescotty
- Joined
- Aug 8, 2006
- Messages
- 13
First off, I am aware that the whole generator/backfeeding/transfer switch subject seems to often lead to hot tempers. I'd like to avoid that discussion in this thread.
I am also very aware of the dangers when backfeeding a breaker box using a generator.
I have purchased a small generator to power my furnace, fridge, and freezer in case of a power outage. The fridge and freezer will be powered using extension cords that I string out when/if the power goes out. Not an option for a hardwired furnace, of course. I am aware that I can purchase a transfer switch for the furnace for around $90, but since I only paid $100 for the generator, and there's pretty low chance that I'll need to use this setup (I wouldn't have needed it in the 7 years I've lived here), I'd of course rather put the money towards something else. However, knowing that when the power goes out at 3 in the morning you might not be thinking straight, I want to utilize a transfer switch to make it foolproof.
So, here is my proposal. Rather than buying the aforementioned transfer switch, I would like to build one using a DPDT toggle switch. For $6 or so I can buy one, rated for 20A 125V AC. My furnace circuit is 15A, so this should be sufficient. I understand this is not the inductive load rating, but since my furnace has a solid state control board, the blower motor will not start up when power is first applied, since the control board goes through some self checks first. The DPDT switch would break before make, and would switch both the live and neutral (the ground would stay connected). I'd mount the DPDT in a box next to the furnace, along with a receptable, something like this:
http://www.4.midlightelectric.com/acatalog/Leviton105066.html
I believe that this should function the same as the purpose built transfer switch. Is there anything that I'm missing here? If your answer is "Just buy the purpose built transfer switch", I'd like to know what function it has (besides the nifty light) that my version does not.
Thanks!
Scott
(oh, and the furnace is in the garage, so that makes it on topic, right?
Thanks!
Scott
