Cable loppers on thin strand wire
seagull369
Would this big boy pictured below be able to cut thin-stranded welding cable or is it meant for thicker strand stuff? I have some 1 gauge down to 3/0 wire that that I want to cut for different projects.
The cutters are rated for (up to, I'm assuming) 1000 MCM copper.
The 52 Ford
Virginia
It'll cut it like butter. I routinely use these on stuff up to 2/0:
Same. Honestly, in a pinch I've used pruning loppers on copper and aluminum without any trouble. You can also get ratcheting cable cutters that are a lot more compact and can still cut the big stuff.
Sent from my SAMSUNG-SM-G891A using Tapatalk
seagull369
Someone was selling it locally for $30. It's a Klein 32". Kind of overkill for my needs, but beats using the Dremel with cutoff wheel as I had been. One of the jaws is nicked a bit, which of course was not the side the seller decided to take a closeup of in the ad. Maybe it can be dressed up. The price for the replacement jaws are about 95% of the cost of the entire tool :wtf:
Just dont try to cut hard wire with them. AMHIK.
Thanks. I wasn't planning on it, but I'll be extra cautious.
rlitman
Long Island
Those small, single-handed wire cutters will easily cut as large as 4/0 fine strand cable. Heavy strand 4/0 becomes a bit of a struggle.
I deal a bit with 2/0 marine battery cable, and my small Klein ones do cut it just fine, though using two hands is required for that size. I also have a HF knockoff I got for $3 that doesn’t have nearly as “sharp” and edge. That too cuts the 2/0 battery cable, but it is a struggle.
Welding cable has an insulation that cuts more easily, but the strands are about the same.
As for the OP’s find, a small nick may be pushed back with a sharpening steel, or even a delicately applied hammer. That’s what happens to these when someone uses them to cut steel.
Norcal
Most here know already but they should only be used to cut copper or aluminum cable.
