Breaking welds on square tube parallel welded together
branimal
I got a bunch of free metal (12 ga 1 1/4" square tube) from someone getting rid of a TV set storage box. 8'x6'x4'. It was a pain in the a** cutting it up with a 4 1/2" grinder, but hopefully it will be put to use with future welding projects.
The base of the storage box has 3 square tubes parallel welded together. I tried cutting the welds and breaking it loose with a 3/4" cold chisel and a framing hammer. No luck.
How would you guys go about breaking these welds?
Jackfre
N CA
Thin wheel angle grinder is quickest. I would give my M12 Milwaukee sawzall a run at it too. Tough to do, time consuming and a lot of waste, so you will have to decide if it is worth it.
branimal
a TV set storage box you say?
That is not something of which I had previously heard.
It’s was used to store chandeliers that were used on set for the production of a tv show. Yeah my description wasn’t really clear.
In my opinion the box was way overbuilt.
Jeffh40
SW Ohio
When I saw the title of the thread, my first thought was to tell you to look up an Arc-Air since it does a great job of blowing out welds.
Now that I read the rest of the post, I recommend just giving them to the local scrap guy if all you have is a cold chisel. If you have a grinder though, it wouldn't be that big of a deal to cut them out.
BukitCase
Oregon
Depends on several things; they're just skip welds, a decent .045" cutoff wheel wouldn't be too bad - especially if you've priced new steel lately... Or (like I did) you could use that to justify a Hypertherm plaz; the scarfing tip for that works a LOT more "surgical" than arc-air (BTDT) and you can still HEAR afterwards :shocking: ... Steve
