Connector Help
tyme2par4
NH
I'm in need of a connector that can splice 4 #10 and 1 #8 wire.
The application is for the slide power in my RV. From the factory it came with a BIG wire nut, but I've already had one of the wires work it's way out, and it's only been a couple months.
I could use a crimp sleeve, but that would make maintenance difficult.
Split bolt would also work, but I hate dealing with all the tape.
I think a Wago Lever Nut would be ideal, but I don't see any that go up to 8AWG.
Space is at a premium too, so the smaller the better.
thanks
thecj3man
East TN
I have used the large metro-pack connectors for #10 wires in automotive applications. The 630 sized connector is rated to 46 amps.
Norcal
I have used the large metro-pack connectors for #10 wires in automotive applications. The 630 sized connector is rated to 46 amps.[
You should never use automotive connectors for line voltage applications although the OP has not specified exactly what the function of the wire they are trying to connect is.
T
tyme2par4
NH
it is only 12V DC
wyliesdiesels
Modesto, CA
he said in the OP that its for his slide power which would be 12VDC...
also you should fix the quote script at the end so its not messed up when people quote you
Dustball
Hudson, WI
Anderson Powerpole stackable connectors.
https://www.andersonpower.com/shop/wire-to-wire/powerpole.html
teamextreme
Lakewood, CO
Google Ilsco power distribution block (PDB). They make a million different configurations and styles. These would work if you have a place to mount the block and would be very clean and make maintenance a breeze. Could be pricey, depending on the model you select.
alfredeneuman
Fullerton, CA
Any wire nut that the wires can work their way out of was not installed correctly.
What kind of warranty do you have? Any modifications are likely to void the warranty.
T
tyme2par4
NH
Am I reading this correctly that it is a couple of month old RV ? Why would you not call the manufacturer and tell them to fix it ??
The dealer is a 3 hour drive away. I'm not going to drive 6 hours for a $5 repair.
Plus they wouldn't be able to get me in for several weeks.
Changing a wire nut isn't going to void any warranty.
alfredeneuman
Fullerton, CA
If you do it completely differently you can't guarantee that. Why don't you just make up the original wire nut correctly then? It would just involve 1 termination instead of 10+
