Kevkx125 garage project's
K
Kevkx125
DOUGLASSVILLE, PA
Changed the wheel chock on the M/C lift.
K
Kevkx125
DOUGLASSVILLE, PA
Mounted a air hose next to the garage door so I have access to air out on the driveway.
K
Kevkx125
DOUGLASSVILLE, PA
Yesterday I put the h/f motorcycle tire changer on my manual tire changer.
K
Kevkx125
DOUGLASSVILLE, PA
Finished putting the bins on the rack I now have 60 bins per side, now the fun begins labeling them,
captain14
Kevkx125
Is the parts rack top heavy as you move it around the garage? Or did you add heavy items to the bottom? Is seems pretty tall. Height and width?
I looked at your other thread and you showed some new tools!
K
Kevkx125
DOUGLASSVILLE, PA
Kevkx125
Rolls nice and steady, don't know the height and width, will have to check picked up a new 3/8 drive flex head ratchet and die grinder
K
Kevkx125
DOUGLASSVILLE, PA
Kevkx125
Hey captain14 I checked the measurements as follows the base is 18" wide and 24" long and it is 62" tall.
K
Kevkx125
DOUGLASSVILLE, PA
Went to a local car show tonight, when I got home I went out to the garage and started working on my mustang. Put it up on jack stands so I can pull the trans and clutch, I got as far as putting it up on stands and pulling the shifter.
K
Kevkx125
DOUGLASSVILLE, PA
Got the drive shaft out and all bolts associated with the trans loose or removed so trans is ready to come out
K
Kevkx125
DOUGLASSVILLE, PA
Used my new to me mower lift, helped with cleaning under the deck much easier
K
Kevkx125
DOUGLASSVILLE, PA
Washed the trans for the mustang, hope to get it dropped off at my friends shop so he can rebuild it.
Ohmthis
Outside of Louisville KY
Kev, those transmissions are super easy to rebuild. There are a bunch of videos out there. If you were closer we could do it on a Saturday, assuming no major damage. Great projects, I dig the older 125.
K
Kevkx125
DOUGLASSVILLE, PA
Ohmthis I hear you on the rebuild but when I say a friends shop I am mean Bob hanlon @ Hanlon motorsports a t-5 trans shop. Thanks for the comments on the 125, small bore two stroke's forever !!!!!
Ohmthis
Tire rack looks good! How high off of the floor is it? I plan to make some higher shelves to store less used items. I’m just not sure how happy I will be climbing a ladder to get something 10’ off the ground.
K
Kevkx125
DOUGLASSVILLE, PA
Thanks for stopping in, the rack is mounted 7ft off the floor, right above the man door.
BlakeTheCarGuy
Roanoke Virginia
Looks good , not in bad shape, is it a super beetle?
Yep it’s a super beetle. 1973 with a 1971 shell pretty much. The frame and pan is a 1973 and the body rusted out so they replaced it with the 1971 body which is why it has the flat windshield. Here is another of my favorite pictures of it. 24D8FC3B-207C-439B-AC5D-5478EBADF2CA.jpeg
K
Kevkx125
DOUGLASSVILLE, PA
A project that went smooth I changed the oil and filter and spark plugs in my d/d.
K
Kevkx125
DOUGLASSVILLE, PA
Sanded and polished the headlights on my d/d
before........................................................................after
K
Kevkx125
DOUGLASSVILLE, PA
Between yesterday and today I finished getting the snow blower ready.
K
Kevkx125
DOUGLASSVILLE, PA
Started changing the exhaust on my focus tonight, will hopefully finish it tomorrow after work.
