Currently under a renovation project of two story dwelling
Based on budget constraints
While the 1st floor ceiling is open and a front room needing a head unit
The line set would run front to back through the 1st floor ceiling joists.
The outdoor unit will be located in the rear of the house
Want to rough in a line set with wire control for future use on mini split.
Can anyone recommend what they would use.
Is there a universal size of the line set and wires for the controller?
Can the line set be precharged or left open to the air for an extended period of time?
Want to install the line set for future use and want to drywall the ceiling closed for cosmetic purposes and have the line set come out of the exterior wall to the main outdoor unit. Would you leave it long or cut it and then braze or couple it in the future?
Thanx for your suggestions and comments in advance
