Hello everyone, Drivesitfar asked me to post some pics of my most recent rebuild. While there is only a small amount of repairing with this vise, there are a few things that some of yall may find helpful.
My Wilton C0 before:
View media item 111561
And After:
View media item 111857
Of note on this rebuild, I could only get one pin out of the pipe jaws so I painted them in place. I guess I could have drilled them out and made new pins but that is something I will need to look into at a later date.
The handle was bent, and I have been making new handles for almost all my vises with damage handle, so I fabricated a new one for this vise as well. Someone here on the forum suggested using high strength 1144 stress relived carbon steel for the handles and this is what I have been doing ever since.
https://www.mcmaster.com/steel-rods/material~1144-carbon-steel/
For the end balls I try to reuse the balls from the original handle but if they are too small or badly damaged, I use Low-Carbon Steel Balls.
https://www.mcmaster.com/balls/material~low-carbon-steel/
I have a metal lathe and these balls are case hardened, punching through the outer hardening is a bit of a process. There are other steel balls available that are not hardend and that may be a better option for some of yall.
I normally order the closet steel rod in size as I can get, and McMaster-Carr has a good selection. If needed, I will face each end, then turn he rod to the size needed. Once turned, I will dry sand the rod with 60, 80, 120, 150, 220, 320 grit sandpaper then wet sand with 400, 600, 800, 1000 grit sandpaper. Lastly, I apply Mothers mag and wheel aluminum polish. Next, I turn the ends of the rod to fit the diameter of the doles that will be drilled into the balls.
View media item 111742
Next, I face one side of the balls. Center drill it, then progressively drill the center out until I get the proper sized hole. In this pic, I am drilling a reused ball from my Reed 204 1/2R rebuild.
View media item 111178
Next, I place the rod in a vise and weld the end ball on the rod. I am by no means a good welder and I only have a stick welder so the weld may not look great, but it gets the job done.
View media item 111854
View media item 111855
View media item 111856
Once one end is done, REMEMBER to slide the rod inside the spindle nut the weld the other end the same way. I am sure no one like cutting the rod, turning it again then drilling a new ball to get it right the second time (albeit an inch shorter).
Next, I use a belt sander to grind the weld down the place the rod back in the lathe at a slower speed to sand the end balls (yes that can be tricky with the spindle attached). Again, this is the Reed handle.
View media item 111183
Anyway, that’s my handle fabrication process.
Another thing I did on this Wilton is some marginal casting repair. If you have some small damage to a casting like small holes or slits from grinding wheels, I like to use PC-7. This is a 2-part epoxy that when cured is machinable, you can even tap it. No, it is nowhere close to being as strong as a weld or the cast iron; however, if it’s a repair you plan on painting over and it is not in an area that will be subject to abuse, then this is a good choice. Once mixed and applied, you can use a wet finger to smooth it and reducing the amount of sanding needed to clean up the repair. You could even texture it with sandpaper to make the repair (once painted) look like the rest of the casting. On this Wilton, I used PC-7 to fix all the damage I caused with the drift pin when I was attempting to remove the pins on the pipe jaws. Additionally, the tail end of the vise has some small broken edges where the tail cap inserts. Here is the tail end with the PC-7 applied.
View media item 111738
And here is the painted tail end complete.
View media item 111858
Anyway, if anyone wants to know more about the repairs I have done on this vise or others, fell free to check out my workshop build. I link all my builds there. If there is anything on those builds that yall find beneficial, let me know and I will add them to this vise repair thread.
https://www.garagejournal.com/forum/showthread.php?p=9046007#post9046007
I hope I wasn’t too long winded.
Have a good one.
