Osprey 1 - Racedeck 0
driftpin
No, I dunno this is actually Racedeck, it resembles it, though. Video from the UK, where the ground mat takes-flight while the Osprey departs. It's a hospital trauma helipad area, not-paved.
Those of you with short attention-span can immediately go to 2:20. I believe there is a favorable comparison between a hot stripper and the Osprey: when either is workin'-it, you cannot look-away. You have-to watch.
budget76
wonder how close it got to flipping into the prop when it lifted up. also curious who signed off on having a floating 'pad' at a helipad and couldn't see this coming.
Kaizen
New England
I ain’t no aeronautical engineer but I don’t think I would have built that.
Seriously though probably has been fine for years using medflight size helicopters.
kbeefy
Harington, Eastern Washington
Unsecured items and/or FOD was always bad juju on the flight line.
I watched a cardboard box get blown up and sucked into the rotors on a wildfire base.
Grounded my helicopter for a couple days while we did 'sudden stoppage' inspections.
If it was much bigger than cardboard all the gearboxes would have had to been sent in for NDI.
aka Larry
Eastern, NC
That has to be super dangerous had that **** touched the chopper.
Said damage would not be cheap either. According to Wiki, the price tag for an Osprey is approx. $67 million.
I guess concrete wasn't in the hospital's budget.
Sumboodie
AK
I worked at Ted Atevens for a while. It was nuts on how lax vs on Elmendorf.
I lost a shovel off my dumptruck, the clamp popped open. They were like "meh, it'll show up someday, just grab another"
That would have shut down the line on base and a LONG shift searching until found.
Was often I'd pretrip a truck or equipment and find random tools, bolts, etc that someone forgot or hadn't bothered to throw out.
One night they went out with a snowblower that had been acting up, set it to kill mode, ran into the snow berm and launched a chuck of ice THROUGH a FedEx plane that was taxiing a few hundred feet away.
That one caused a safety meeting since it was like $45k in damages
58Yeoman
Central IL
Hey boss, I figured out a way of saving the hospital some money. Instead of paving the heliport, let's just use the old rubber flooring from the basement...
Sumboodie
AK
I had no idea the USAF even had the Cv22.
I dealt with munitions so F15s, F16s, A10s, B1, B52, F22, etc.
nadogail
Coronado, CA
Turbine Engines are like vacuum cleaners on steroids.
They ****, Sueeze, Bang and Blow. If something is loose the sucking turbine will try to eat it even if it's allergic to what it ingested.
The technical term for this allergy is FOD, Foreign Object Damage.
