gun oil for rust-protecting exposed vise parts?
eidolon
Columbia, MD
I have read through some posts with conflicting suggestions regarding paraffin wax and various oils (have not seen gun oil discussed, though I may have missed it), most of which have been either dismissed or pretty divided in their claims.
I was wondering if anyone have good accounts on using gun oils as a rust inhibitor for rust protection. Full disclosure, I am attempting to rust-proof an old American vise.
Thank you in advance!
toolchaser
Greenville, GA
I think the gun oils work best on blued or parkerised surfaces. On bare metal not subject to a similar surface conditioning treatment, I like a product called " Rust Inhibitor" by Cyclo . Its intended for inside dump truck beds, so it leaves no oily film once you dry buff off the haze.
logan09
Upper Michigan
I use food grade mineral oil. You can get a gallon of it for $25 or cheaper. I have 1 or a hundred guns/swords that all have a coating of mineral oil. No issues.
Iowafox
Iowa
I use mineral oil, 10w30, silicone spray. I find as long as it gets cleaned after each use and whatever oil you can get is good.
brownbagg
mine been outside for over thirty years with no oil, it just works, no rust either just china pig iron
Gunfixr
behind the house
For the most part, gun oils are a much more finely filtered light oil, not really all that special.
Personally, for corrosion protection not requiring something that dries on, I like ballistol. It is an old German oil, and likely has a lot of mineral oil in it. It was developed as a gun solvent/oil for the older corrosive primed ammunition. It neutralizes salts, such as sweat. It takes a very long time to dry up. I used it when I shot cas competition, using blackpowder. It is very corrosion inhibiting.
Jackfre
N CA
I use Johnson’s paste wax on all my Cast iron tables and other shop iron. No silicone so on wood projects it doesn’t pollute glue up surfaces. It does a good job on the table saw, jointer and band saw tables. Haven’t used it on the vice, but should be good there as well.
niget2002
Josephine, TX
same here.
macgee
Sepulveda Pass, CA
BoeShield works great and doesn't leave a slimy wettish layer like Fluid Film.
I've also had good luck Johnson’s paste wax or Carnauba wax but you have to apply several coats and really rub it in to build a hard clear coat. Try-Flow also works great and an awesome lubricant.
Don't use WD40, its rubbish as it contains water and hardens up in a bad way.
