bradpac
So researching it seems I can use a 320/400 amp dual lug meter to replace my current 200 amp meter and run to my current house 200 amp main breaker ~3ft away. For the garage it will be about a 30ft run, what size wire should I run to the 200 amp main there. Also, it appears if I put a breaker below the meter on the feed to the garage, that makes the garage a sub panel and it has to be 4 wires with ground instead of 3 wires. A breaker at the house for the garage sounds like a good idea, but does that change my wire sizing? The service to the garage will be ran underground in conduit and inspected per code.
Can anyone post links to the best components to buy for this setup or just grab a meter base from HD?
