KMScott
Smitty
Thanks for the photos. It seems that the nut on mine was never drilled. I got it from a guy who pulled it out of the weeds and the first owner didn't seem to know much about it either. I'll drill the holes and get it back together. I just have to track down some pins or drill rod of the right diameter to make some.
You can get knurled pins here, most Wiltons used 1/4 diameter. Another option is to drill and ream for a 1/4 and tap the Static body for a 5/16:18 long set screw and turned the set screw end down to a 1/4 inch for easy removal. I wrote a blog on how I did it. Good luck.
https://www.mcmaster.com/knurled-pins/shaft-type~knurled/
https://wiltonviseparts.wordpress.com/2016/01/25/those-pesky-wilton-end-cap-pins/
