Walls off - Extra Garage Electrical?
HamAndEggs
Houston, TX
I now have 200a service in my garage with a nice big panel
I already have 2 lighting circuits and 3 x 20a receptacle circuits (One for each wall), 1 for garage door opener and 1 for networking equipment
I plan on adding 2 circuits for electric car charging
Other than all of the above, what should I add in? Running wire right now is trivial. I am into light woodworking, have never welded (But might want to one day)
What makes sense to add in? Any ideas welcomed!
jeepxj
conduit to the far side with a pull string if you're really worried.
78SC4X4
Port Orchard Wa
Not sure what your size is, but I would have 20a receptacles every few feet. At a minimum, I would want a 30a 220 for a table saw and a 50a for welder.
u2slow
BC
I
Trivial for me too so I didn't. :lol_hitti
I run what I need when I need it... surface conduit.
Innovate1
You don't say what size the space is. A receptacle every 6 or 8 feet is plenty IMHO. I alternated which circuit they are on so I can fully load adjacent ones without tripping a breaker. I also put a 3/4 conduit up into the ceiling and to the middle of three walls with a 4 x 4 deep box and dual gang mud ring so I can put in whatever I need later.
geneg
Midwest
I agree with the 6-8 foot spacing per wall & 1 in each wall shorter than that. (1 on each side of oh door). If you will have a workbench, put a double duplex above its location. Add exterior recepts where convenient. Did you use gfci breakers? If not, use a feed thru recept as first on each wall circuit. After you decide how you'll use the space, add 220v recepts for compressor, saws, welders, or ?
andyvh1959
Green Bay WI
In my new 24x28 detached garage/shop build I installed duplex outlets every four feet on three walls. On the west wall (where most of the equipment will be) I have two circuits of 20 amp outlets. The other walls have two circuits of 15 amp outlets. So I certainly have enough outlets. Perhaps every six feet would have been enough, but every eight feet would have been too few spacing.
dcg9381
Austin, TX
I say 1" conduit thru both walls, so if you ever need to change something you can change it.
On my shop, I love these Siemens Talon sub-panels. They come with 3 breakers, 3 outlets: 50A 240v, 30A 120v, 20A 120V GFCI. They are very flexible and for $150, they're a great value.. can be mounted outdoors if you want.
Craftfab
Garage
Don't forget ceiling outlets for any machines you may want to mount up there, like air filtration, or for cord reels/drops for equipment placed out in floor of garage. If you want ceiling fan(s) or outlets up high for a tv or any signs etc.
Max
Georgia
For woodworking your AC needs will depend on the size of the equipment you want. For example, my contractors table saw is 1 HP so 120 is fine, but my Unisaw is 3 HP and 240 only. My soon to be replaced 14” bandsaw is 120V, but the new 17” is 240V as well.
For my needs, I need 3 240V outlets - 1 for the unisaw, 1 for the dust collector, and one for the band saw. If I ever upgrade my jointer or planer I’ll need more...
I agree that outlets every 6 feet or so are fine, but around a bench I’d do more. Also ceiling outlets for a dust filter setup, garage door openers, and a reel extension cord as well. Lots of people like garage outlets a bit over 4 foot high so you can put drywall or plywood on its side and not block them.
