Silence is golden
mercifiknow
Somewhere I should be
Anyone every try silencing a generator or compressor by doing any of those things on YouTube? Curious to see if some one actually tried this with some real world experience.
I plan on doing a box of some sort in the new place.
Pntyrmvr
Headwaters of the GTA, Ontario
Guy I knew plumbed the exhaust through a 5 gallon bucket of water.
Left a toxic mess to be dumped after the weekend, but he said it worked.
“Talk is cheap. Whiskey costs money.”
sweetk30
finger lakes area upstate ,ny
Off this site i did 2 compressor build were i mounted each part on rubber pads and it got me a LOT less harmonic noise . Then a good silencer muffler intake filter helps also .
I have heard of people doint the intake threw a small 4cylinder exhaust muffler and it helps alot .
larry_g
oregon
If any of them u-tube guys are promoting a labyrinth then yes they do work. We used them in the factory where we had to have a compressor or vacuum pump local to a machine.
http://lumberjocks.com/topics/36276
I don't have a fan for you but the link above has a good description of a labyrinth noise filter. We used them on some vacuum pumps where I worked to control noise and they worked very well. Noise mainly travels in a straight line so the interlaced panels with noise canceling foam on them kills the noise but allows essentially free flow for the air.
lg
no neat sig line
lg
no neat sig line
Forgottonia
edge of Forgottonia
I've been planning to build a small, attached storage box just outside my shop for the compressor and a couple other bulky things. I'll route the air through the wall.
After reading this thread I'll also look into trying to make it a bit quieter. It's a 20 gal. Craftsman, and it's crazy loud.
Honch
Danville, IN
lg
no neat sig line
I agree with this, Polar Air, Emax and Flexzilla all offer reduced noise compressors using a labyrinth type intake system. A friend of mine has one and you can carry on a normal conversation standing next to it. Short of a complete enclosure this is probably the best way to make a compressor quieter. Emax was selling the systems separately for under $300, I don't know if they are still available.
didit
S.W. Ontario
My noise reduction set up is getting old and needs to be replaced but was pretty effective since built in 1984.
I built an enclosure with about 12" of clearance around the perimeter and above the cylinders. The enclosure is on the outside of the garage, on the north side where it is the coolest and shaded. It is basically just a box with a removable front for easy access. The box was framed with 2X3s stud walls that were staggered on 2X4 bottom plates. It was then insulated with hard foam freezer panel sheets. The staggered studs keep sound/vibration transfer to a minimum. The removable front is built the same. My garage is climate controlled and I have a fan that pipes air from the garage into the enclosure automatically while the compressor is running. The intake filters are an upgrade to the type that were original and were an improvement. It is a 5HP cast iron unit with an 80 gal tank, that was the smallest one built by London (sold under various names) at the time They built very large industrial compressors at the time. Other than general maintenance I have only replaced the automatic pressure switch and the tank drain a few times. I'm back to a manually operated drain on the tank. The compressor is still bolted to the 2X6 skids it was shipped on that sets on a 1/2" rubber mat. I use a flexible rubber hose from the compressor through the wall to my cooling tower mounted on the garage wall.
I am planning on building another to replace it. I have houses built on either side of me now that weren't there when first installed. Got to keep the peace.
mercifiknow
I bought a Kobalt pancake compressor early year and standing next to it, you can carry on a conversation pretty well. My early 80’s 20-gal SpeedAire you can’t carry on a conversation 2 counties over with it running.
I will check on the labyrinth muffler and the rubber feet were gone when I got it so I know that’ll be one of the first things I buy. I also plan on buying one of the good silencers like Solberg (at least I think they are good). Puma makes one too.
I’ve heard the heavy duty rubber mats also make great dampers as well.
CoogarXR
I have a shed right behind my garage. I just moved my compressor back there. I can hear a faint hum, that's about it.
