Coasters and Heating Pads?
lbperry
North AL
This topic isn’t probably appropriate to this forum but i’ve seen some good replies on a wide range of subjects so here goes:
It seems to me that with all the thermodynamic study done in engineering and aerospace it would seem that someone could design a drink coaster that would process the condensation from a glass so it doesn’t puddle at the bottom in a standard coaster. I use a “thirsty stone” or cork coaster. Anybody else got any better solutions that I could try.
Thanks for any inputs or opinions.
Throughfaith323
Could probably use unfinished wood that is dry and very porous. Should work until it’s fully saturated.
Forgottonia
edge of Forgottonia
The coaster next to my favorite evening chair is a 3.5" square piece of 1/4 inch unfinished plywood. I can attest that it will fully absorb all the condensation from four sequential glasses of whiskey on the rocks.
If need be, I could test to see if it absorbs condensation from the fifth and sixth glasses as well.
CraigStu
Blacksburg, Va
Silicone coasters.
https://www.amazon.com/dp/B079DKSJRV/?tag=atomicindus08-20
Search as they are available in a wide range of colors. Get the largest diameter you find. I got these last summer and am very happy w/ them. They have enough capacity to contain the water and then it evaporates. They do not adhere to the bottom of your glass either. And they can be used as a hot pad. Once they get a little funky, throw them in the dishwasher.
gmcgeo
quicker picker upper
Jinks
Daytona Beach
Here in Florida the humidity will puddle around a cold drink in an instant. Cork, thirsty stone, none of the commercial coasters will help. I've had 'em all. Got to thinking about it one afternoon & talked my wife into fixing it for me.....:D I got her to sew some terrycloth covers for regular coasters. She uses some elastic at the edges so they slip on & off. The terrycloth absorbs the moisture & leaves me with a dry glass....:thumbup: Not really rocket science....:dunno:
L
lbperry
North AL
Thanks, CraigStu. I’ll have to try some of those.
Ditto Thanks, Jinks. I’ll try to get my wife to whip up a couple of these and see how they work.
niget2002
Josephine, TX
My coasters are made out of Ash. It soaks up the moisture.
Alternatively, I mostly just drink out of a Yeti type cup. The double-insulated walls keeps moisture from accumulating on the outside of the cup and helps keep the beverage nice and cool on the inside.
