MarineScott
What are you using for cutting fluid? Do you use a homemade mix, or an over the counter brand? I would use it mainly for cutting threads, or drilling.
This. The UB stuff is awesome. Although I mostly use a small can of Tap Magic or basic Mobil thread cutting oil 'cause I'm cheap.Union Butterfield makes an excellent drilling and tapping fluid. It’s fairly thick so it sticks to the tap, doesn’t have a bad smell, and it works well.
The old Moly Dee formula before the good stuff was taken out of it? That stuff is getting hard to find these days...I used to use Cool Tool 2 but it would go into a weird congealed state if left a long time plus also staining and the plastic bottles were prone to fracturing at the bottom, leaking all of the fluid out...so...
Since then the "Magic Tap" aka Tap Magic has been getting it done. It appears the 4oz metal can is done-for and they have plastic dropper bottles now.
I have some Castrol Moly Dee around if I think the material is going to be extremely difficult to tap. That horse doesn't come out of the barn very often.
Where are you guys buying this? ive thought about tap magic from Amazon but don’t know about having a fluid shipped
Our local Tru value and Ace both carry different brands of cutting fluid.Where are you guys buying this? ive thought about tap magic from Amazon but don’t know about having a fluid shipped
I’ve used soap for years on wood screws and drill bits, but never on metal products. Might be worth an experiment.I've used Tap Magic which works as expected, but I always need more for drilling. Sometimes I use air tool oil if I have nothing else.
I had heard of an old trick to use bar soap (Irish Spring I think) to coat drill bits and taps. Supposedly the soap sticks to the bit better and helps cut without flowing off the work. I have not tried it, but have heard that it works great.
