Max78
I have a 30x40 slab that needs to get done and I'm doing all of the prep work. I have an area that is flat, but not level. One corner is about 5 inches lower than the other.
I have an old Mustang 440 with too large of tires and a bucket that is rounded on the bottom so it works poorly for dragging backwards to cut the bumps and fill the lows. I have managed to improve the grade, but I'm still 2 or so inches away and I have run out of skill on the skid steer.
I have thought of tilling it up and just manually using something like a screed board to get it level, but that seems a bit over the top?
If anyone has any tips or tricks to getting a somewhat large area to the same grade any insight would be greatly appreciated.
I use a water level and a story pole to check grade.
