Conduit, outlets and switches on garage walls
thaxboyd
Utah
The garage is set up with 100 amp service and have the breaker box on the wall... getting ready to install outlets and such. I do not want to cut open the drywall to put it inside and have decided to run it external. I want it to look as nice as possible and was looking for ideas on what boxes and conduit everyone recommends?
NUTTSGT
Northern Central Ohio
EMT would look the cleanest but if you can't bend conduit, you'll have an issue. If that's the case, you may want to go with PVC. Simple to cut/glue together. You can also heat and bend to desired shape.
T
thaxboyd
Utah
I don't mind that look at all. Kinda ads an industrial look to the shop. Looks as if the boxes have tabs for screws, is that right? Thanks for sharing
Yankeefarmer
Connecticut
Yeah, they are the PVC single and two gang boxes typically used for outdoor installations. A bit more expensive than steel, but I didn’t want to paint steel and I didn’t want to see rusty metal boxes years down the road.
Duke74
Pierceland
The problem with pvc is that it’s hard to make it look neat unless you want to strap it every little ways. Emt can be strapped every 5 feet on a run, once you have strapped at an outlet box. Emt will not sag like pvc will.
Yankeefarmer
Connecticut
I ran mostly 3/4” pvc. Code says it must be secured every 3 ft. Can’t see how it’s gonna sag at those intervals.
Bert_
NW Iowa
EMT and 4sq metal boxes.
Even with lots of straps the PVC will turn wavy when the temperature changes.
rburke65
Canfield, Ohio
It’s just a personal choice....PVC or EMT. Myself, I vote for the EMT and 4”x 4” deep boxes. There are instructions on line on How to bend conduit
Shiftless
East Bay SFO
Here is another vote for EMT.
Just get yourself a bender, watch a few YouTube videos, and practice bending on a few lengths of tubing. Sure, you’ll make some mistakes, but EMT isn’t too expensive. My little shop has only about 50 feet of half inch with more than a few bends. I used all 4x4 boxes but only one deep one where I needed a junction box with more than a few wires. No 240V wiring as of now.
Duke74
Pierceland
Are your 4x4 boxes labelled 1900? Ours in Canada are Iberville made. They are 52151k for regular ones and 52171k for the deep ones. They give you 1/2 and 3/4 knockouts.
Terry D
St. Louis, MO.
Its slang here. Its a original part number from a long time ago. I've always called them that, when I came in the trade, that's what everyone called them. If I go to a supply house, I ask for a deep or shallow 1900. Probably the same box you are referring to.
Bert_
NW Iowa
I've never called the 1900 boxes. When I call in an order I just say 4SEK or 4SDEK, for shallow and deep, since the supplier I use carries Appleton.
Noltz
Ontario, Canada
I ran PVC. Secured at 2' instead of 3' on the horizontals, but it's unlikely it'd have sagged either way. I can't bend EMT and honestly I prefer the grey. It's also easy to reconfigure.
T
thaxboyd
Utah
I find it strange that you wo7ld drywall before you wired, but....different strokes.
Hmmm, I should have came out here when they built the house way before I owned it and had them do it. But I was slow getting here. Where is the eye rolling emoji?
Duke74
Pierceland
surface-run emt conduit is the way to go for a shop. It makes it a lot easier to feed something in the future that you might want to add. As long as you have room in the conduit for extra circuits, it’s a cake walk. Plus, if you wanna add another receptacle or light fixture. Lots of times all it takes is a short piece of conduit to get there.
nadogail
Coronado, CA
Benfield wrote the best book on bending EMT. I used it, along with the video 20+ years ago when teaching electrical wiring.
